      10-16-2013, 04:52 PM   #1
Chee_Dog
Drives: 07 328xi
CEL Code Help
Just thought I'd post on here to get some additional help aside from my own diagnostics. If anyone is keeping up with my build thread I am rebuilding my z4m roadster from the dead. There are 10 cel codes so bare with me. The car will be going to the shop soon but i prefer to figure some things out myself if possible and save money one labor and repair cost. thanks in advance.
1) p0072 - Temp. Sensor - says low input.
2) p1644 unsure
3)p0113 intake temp sensor - hight input. I assume the maf needs to be clean or a new one needs to be replace? I do have a cone filter and not oem.
4) p120D - unsure
5) p0140 - 02 sensor circuit not activated - o2's are dead or needs cleaning?
6) p2185 - coolant temp sensor 2 circuit hight
7) p0013 exhaust b camshft position actuator - Bank 1
8) p0010 Intake camshft actuator circuit open bank 1
9)p0140 - 02 sensor circuit no sensor (dead o2 prob or needs to be check)
      10-16-2013, 05:14 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
I'll take the easy one
Ambient air sensor is under the left side of the front bumper.
It's a little probe sticking out of a hole in the left side plastic box near the bumper fang.
      10-16-2013, 07:14 PM   #3
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
I haven't seen your build thread but for starters have you checked all the fuses in the DME?
http://www.zpost.com/forums/showthre...O2+sensor+fuse
      10-17-2013, 07:08 PM   #4
Chee_Dog
Drives: 07 328xi
yes i did check all the fuse, they're all good. Where is the exhaust camshaft and intake camshaft sensors located?
      10-17-2013, 07:32 PM   #5
StickMon
StickMon's Avatar
Drives: 2006 MR
Pretty sure sensors at the rear end of the camshafts.
Parts #3 and #8 sense parts #13 and #15 spinning around.
But you said the codes were for actuators, which sound more like a Vanos problem.
I'm assuming from the "P" codes that you're using a generic OBD scan tool.
You may want to get set up with a GT1 knockoff so you can run DIS and get some better diagnostics.
