      07-31-2015, 07:13 PM   #1
JFB06M
JFB06M's Avatar
Drives: 2006 M Roadster ESS VT2500
ESS modified Vortech supercharger Blow-Off valve?
Does anyone have the Vortech Maxflow Race Blow off valve on their ESS supercharged Z?
I am told ESS modifies this valve for their kits and it is "silent while cruising".
What videos I can find are non-ESS kits and presumed stock Vortech valve….and they are hardly silent.
      07-31-2015, 07:32 PM   #2
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Any BOV won't be silent. If you want silent, you need a bypass valve.
The Tial QR is pretty quiet on my non-M.
      08-01-2015, 06:40 AM   #3
Beedub
it looks long.... that may foul the hood.
Edit ; not sure why ess would mod the valve for their use? as then ESS would have to warranty the part as the VT warranty will be void, which i can't see ESS doing. Have you asked ESS if their is a way to stop the VT valve making the whistle noise that bugs you so bad?
      08-01-2015, 01:52 PM   #4
JFB06M
JFB06M's Avatar
I not 100% sure ESS modifies this valve….but was implied when I asked for a model number as to what valve they are proposing…..but their on-line photo of the current VT2-525 has a bypass valve…not this race BOV.
I will get exact measurements before I would order as I am also worried about clearance with the hood.
I am thinking I will just buy yet another plastic intake elbow and buy a Tial bypass valve to make my car as quiet as possible.
I doubt I will be able to remove that plug that was JB welded in place.
      08-01-2015, 01:56 PM   #5
JFB06M
JFB06M's Avatar
I have played with spring pressure adjustment nut…..only made whistle worse.
The filter I attached help only on start up.
      08-01-2015, 06:58 PM   #6
gmd2003
gmd2003's Avatar
352
Drives: 2014 CP M6 and 2006 VT 525 Z4M
Yes I have this valve on my Z4M with the 525 kit .
George
      08-01-2015, 07:11 PM   #7
JFB06M
JFB06M's Avatar
Thanks for that info….so obviously it must fit.
Whistle?
"Silent while cruising"?
      08-02-2015, 03:58 PM   #8
Beedub
george can you post a pic plz
      08-03-2015, 11:14 AM   #9
gmd2003
gmd2003's Avatar
352
Car is at the shop , I am having some electrical gremlins after the rebuild sorted out. I will post pic as soon as i get it back.
George
      08-11-2015, 04:33 PM   #10
Beedub
any updates on this OP??
