      04-06-2015, 04:58 PM   #23
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by SCHMOUPE View Post
Are we supposed to smoke out of that thing or extract the oil with?
yeah, it does rather look like that.
I just ordered the Mityvac 7300.
I found a tech bulletin on their web site that they have changed the gasket that was the cause of air leaks.
      04-06-2015, 06:15 PM   #24
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
I've got the topsider oil extractor and have been happy with it.
http://www.amazon.com/America-5060-T...de+oil+changer
Top Down 365
      04-07-2015, 09:13 AM   #25
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
I really like how simple it is (less points of failure). Just curious, how do you empty it?
The Raspinator
      04-07-2015, 09:15 AM   #26
SCHMOUPE
SCHMOUPE's Avatar
Let us know how it works. I don't like shlepping the compressor out though.
The Raspinator
      04-07-2015, 09:46 AM   #27
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
Talking
I have a topside extractor as well that I use (hand pump, no compressor) so my drain plug hasn't been out for 3 years. I highly recommend it.
      04-07-2015, 02:22 PM   #28
GQM
The Slip Angle
GQM's Avatar
31
Drives: 2007 BMW Z4 ///M Coupe
I've performed a Timesert fix on a guy's Miata that had stripped spark plug wells. It went fine and held up well. Just take your time and follow the instructions carefully. I'd be extra cautious for shavings getting into the pan. Perhaps have some spare oil to pour in to flush anything around the drain hole out before starting the car. Also greasing the tap will help grab some of the shavings.
2007 BMW Z4 ///M Coupe | 1993 Mazda RX-7 Turbocharged 417 whp | 1999 Mazda Miata All Motor 185 whp | 1991 Mazda Miata N/A 13b PPort | 2003 Honda S2000 All Motor 238 whp | 2006 Mazda RX-8 | 1998 Lexus LX470 | www.instagram.com/garagequinnmotors
      04-07-2015, 03:36 PM   #29
SCHMOUPE
SCHMOUPE's Avatar
all great points, I am planning on doing it very slowly in order to minimize the shavings. planning on using some kind of grease on the bits and will do an oil flush to get the shavings out and then fill up.
question for experts, I am planning on flushing the system with some oil to get rid of the shavings after repair. Should I use 10w60 for the purposes of flushing? Or can i get away with some other oil (cheaper)? I am planning on pouring from the top and let it drain from the bottom without turning the engine over. Is this the best way to go forward?
The Raspinator
      04-09-2015, 12:19 PM   #30
GQM
The Slip Angle
GQM's Avatar
31
For the sake of not mixing weights and possibly detergents, I personally would just flush with the 10w60. However, I am just overly anal like that.
      04-09-2015, 12:21 PM   #31
Reborn_
Drives: 2007 BMW Z4MC
Ditto. You would save what, 100$ tops for 5 qts of cheap stuff vs. 5 qts of 10w60? I would eat that 100$ personally.
      04-10-2015, 09:30 AM   #32
SCHMOUPE
SCHMOUPE's Avatar
Thanks guys for the input. I have about 11 QTs of 10w60. Should be enough for a flush and a clean refill.
The Raspinator
      04-10-2015, 10:32 AM   #33
Reborn_
That'll do it. Good luck and please keep us updated.
      04-10-2015, 11:24 AM   #34
StickMon
StickMon's Avatar
Drives: 2006 MR
Call me nuts, but after reading this I'm tempted to install a ball valve.
      04-10-2015, 11:29 AM   #35
SCHMOUPE
SCHMOUPE's Avatar
Attachment 1189842
Attachment 1189844
Doesn't that stick out too far under the car? I would be concerned about damaging it while driving.
The Raspinator
      04-10-2015, 11:55 AM   #36
Reborn_
Ya, I wouldn't do a ball valve. I'd be paranoid of a rock or something opening the valve, or as alluded to above, a rock hitting the valve and breaking it off.
      04-10-2015, 02:21 PM   #37
StickMon
StickMon's Avatar
Drives: 2006 MR
Yea, that's my concern, too.
I might try and map it out with an elbow and see how low it goes.
It would work if I could keep it above the reinforcement plate.
      04-10-2015, 03:05 PM   #38
fdagen
Drives: 2006 Z4M Roadster
Interesting thought. I am surprised car manufacturers haven't done anything here. The ball valve would actually work. There is a undertray and a access port that would protect it on the M. You would just have to look at how much space is required. There may be enough room to allow for something like this.
      04-10-2015, 03:16 PM   #39
Taylorguy74
Enthusiast
Drives: 2016 550i M-Sport
Fumoto drain valve - it has a spring pressured locking notch on it as to not open unexpectedly -
http://www.ecstuning.com/ES2208993/?...FQqGaQodWy0ACw
2016 550i M-Sport
2008 328i M-Sport (Sold)
2007 Z4M Roadster (Sold)
      04-10-2015, 03:25 PM   #40
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I tried one of these on my G35.
JMO but I didn't trust it.
      04-10-2015, 03:34 PM   #41
Taylorguy74
Enthusiast
Yeah, I'd be a little paranoid about it myself. I don't use one, but have thought about trying one out before. I just could never pull the trigger.
2016 550i M-Sport
      04-11-2015, 10:11 AM   #42
StickMon
StickMon's Avatar
Drives: 2006 MR
I figured somebody already thought of this.
That's why I don't have any patents.
Still grappling with the pickle matrix .. GOYVEN!!
Looks like they have several options in an M12-1.5 that look short enough not to stick much below the reinforcement plate.
Pulled the trigger.
Got one for the Wife's truck, too.
      04-11-2015, 02:44 PM   #43
SCHMOUPE
SCHMOUPE's Avatar
For anyone interested in my saga, I finally got everything together and attempted the thread fix this morning. Excited to say it all went perfectly smooth. I managed to snap a few pics along the way. Maybe sometime next week I will sit down and do a proper DIY thread. I am also going to sell my time sert kit.
The Raspinator
      04-11-2015, 02:59 PM   #44
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
That's good news, I'm glad to hear it went well.
