      04-13-2015, 07:12 AM   #1
badhbtz
badhbtz's Avatar
Drives: 2006 Schwarz M Coupe
Crank Pulley (Double stage) front of the S54
Anyone know how to get this thing off? I removed the bolts and there is a black cap that appears to be part of the assembly. I'm not sure I could get a pulley - Puller in there if i wanted too..
Since many of you have done this I figured I would ask!
Thanks!
Chip
      04-13-2015, 08:13 AM   #2
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
I can't help, so I'm just here to gawk at the big power that's on its way
Very excited to see this through! You may want to check out the E46 forums. When I did my VF install, I spent quite a bit of time over there.
      04-13-2015, 08:53 AM   #3
badhbtz
badhbtz's Avatar
Thanks B
I found the TIS manual.. I assume removal is listed in that. Such a weird design. You would think a pully (Puller) would work but I just cant see how.
maybe its just stuck on there and needs to be pryed off.. I just didnt want to destroy the pulley in the process.
Chip
