      04-12-2015, 09:14 AM   #1
badhbtz
badhbtz's Avatar
Drives: 2006 Schwarz M Coupe
V525 Install Questions
Hello all,
I have not been able to contact Roman so I wanted to chime in with the other experts...
Questions: Oil Cooler install - In the images on the flash drive for install the oil cooler appears to be flanges facing down. is this correct? Also there is only one hose I expect it needs to be cut and then attached to the flanges they give you. Routing? Does it just go back up and follow the old path and connect to the old location? I assume so- Its not very clear in the directions.
Thanks!!!
Chip
