      12-21-2022, 01:31 PM   #1
Coi
Drives: 21 X3 M40i, 07 Z4MR
Best Option for M Roadster Third Brake Light?
My third brake light has completely separated and needs to be replaced. It was cracked down the middle when I got the car but now the entire faceplate is broken and is about to fall off. It looks like it's probably the original one that came with the car.
What's the best option for replacing it? I would like to get the same clear/white color again. It seems like the OEM clear ones are actually back in stock at multiple vendors but they're about $120 and will definitely just crack again. Maybe I could somehow reinforce the housing with plastic shims or epoxy?
Aftermarket is much cheaper ($20) but I've read that these don't fit properly or look as good as OEM. Has anyone purchased a decent aftermarket clear 3rd brake light that looked good and held up well?
Thanks for the help.
      01-04-2023, 09:12 PM   #2
zed_fan
Drives: 2006 Z4MR, E60 M5 6MT
I bought a cheap one a few years back and it wouldn't fit at all, so save your money. The OEM was $70 a few years ago when I bought it and now it doubled?? I suppose you could buy it from FCP euro if you want the lifetime warranty exchange.
Tags
3rd brake light, brake light, e85 z4, trunk lid, z4m
