03-31-2022, 10:26 AM | #1 |
Rep 52
'04 radiator flush question
From what I can tell, removing the engine block drain plug might be a bear. Always one that believes in 'work smarter, not harder', plus I'm a little lazy, why not just leave the darn thing alone. Do the simple drain, add more d i water, circulate, repeat several times, measure the amount of water that drains, subtract against the original 10.5l capacity, & add concentrated amounts back in to get me to the desired 50-50. Only thing it cost me was several cheap gallons of distilled or DI water. Thoughts?
04-01-2022, 12:50 PM | #2 |
Rep 18,742
My suggestion...
Buy a Motive power bleeder with quick release fittings. You need one anyway to bleed brakes and the clutch (if you have one). Motive has a neat little adapter that threads into to bleeder screw port used on most BMW cooling systems. You can pressurize the cooling system at 16 PSI or so, then power drain the system through the radiator. |
kaybat125.50 |
04-01-2022, 01:43 PM | #3 | |
Rep 52
Also, I've got one of these guys: https://www.harborfreight.com/brake-...xoCYaUQAvD_BwE Same thing? Last edited by bob'smerlot; 04-01-2022 at 01:46 PM.. Reason: forgot something |
04-02-2022, 01:03 PM | #4 | |
Rep 18,742
https://www.motiveproducts.com/colle...ropean-bleeder https://www.motiveproducts.com/colle...iator-products
rsutoratosu114.00 bob'smerlot10.50 |
