      05-07-2011, 11:36 AM   #1
v3.0si
v3.0si's Avatar
Drives: '08 Z4C 3.0si
///m air box on a z4 n52
i noticed that the snorkel and the mounting points are identical between the ///m and the n52 air boxes....
1) the box for the ///m is larger and contains a larger filter. presumably this means better air flow, also a lower (possibly louder) intake sound.
2) the MAF sensors are different. but how? if the mounting points could be proven to be identical, would using the stock n52 MAF in the s54 box create issues? could any forseeable issues be resolved simply by resetting the "driver learning" throttle mapping back to factory default, therefore forcing the DME to learn the MAF values from scratch?
3) the intake boot inner diameter that comes out of the n52 air box is 83mm. what is the outer diameter of the hole on the s54 air box for its intake tube?
obviously the best way to to do this is trial and error, but i don't have an ///m box laying around, so i'm coming to the experts here for ideas. what say you?
      08-02-2011, 03:11 PM   #2
comics69
France
80
Drives: Z4MC
Did you get the information ? It would be interesting for me
      08-02-2011, 03:18 PM   #3
v3.0si
v3.0si's Avatar
no such luck. i think it's cause the ///m owners on here are shy.
      08-02-2011, 03:20 PM   #4
comics69
France
80
Drives: Z4MC
Ok.... It would be a upgrade to install this airbox. Our box is ridiculous..
      08-02-2011, 03:30 PM   #5
v3.0si
v3.0si's Avatar
100% agree with you. i haven't given up hope though. if i do find out anything, i'll post it here.
cheers!
-eric
      08-02-2011, 03:35 PM   #6
HaiDef
Drives: M240i
M's also dont have the sound resonator or whatever it is called.
      08-02-2011, 03:50 PM   #7
v3.0si
v3.0si's Avatar
the resonator for the n52 is between the MAF and the throttle motor... a potential ///m box swap shouldn't affect that. at least, not that i can see.
      08-02-2011, 04:40 PM   #8
esqu1re
esqu1re's Avatar
41
Drives: M Coupe
Would it be worth the price? I don't know how much a ///M airbox would cost, but AFE intakes are less than $300 IIRC, but look a bit ricey. GL with your inquiry.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
      08-02-2011, 06:09 PM   #9
wassup61
Drives: 2007 Z4 3.0SI
I will try this out and report back
      08-11-2011, 10:03 PM   #10
v3.0si
v3.0si's Avatar
any luck? super curious here!
      08-11-2011, 10:42 PM   #11
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I can rent my stock airbox for someone's trial and error, for a reasonable price + shipping, to be returned in a month
      08-12-2011, 08:31 AM   #12
v3.0si
v3.0si's Avatar
any chance you could be convinced to measure the OD of the outlet, the ID of the MAF port, and the center-to-center for the mounting screws for the MAF?
pretty pleeeeeaaaase?
      08-12-2011, 09:36 AM   #13
ZStig
279
o...m....g
yeah give me some time, I got a busy weekend
      08-12-2011, 10:24 AM   #14
v3.0si
v3.0si's Avatar
o...m....g
haha... i didn't think i was that high-maintenance!
thanks for helping with the cause
      08-12-2011, 11:23 AM   #15
ZStig
279
its fine, measuring is easier than shipping it across the country
      08-12-2011, 11:48 AM   #16
v3.0si
v3.0si's Avatar
      09-22-2011, 10:26 PM   #17
3002 tii
3002 tii's Avatar
2280
Bump
Follow for latest mods
