05-06-2011, 01:15 PM | #1 |
Rep 2,736
would these fit an older Z
found aset of these for cheap and wondering if they would fit a non-M Z4 it be going on a 2006 3.0I
any ideas? http://i825.photobucket.com/albums/z.../P90060220.jpg |
05-06-2011, 02:52 PM | #3 |
Rep 409
they'll fit perfectly; however, 225/35r19 will be widest/tallest tread you can go to in the front without rubbing, unless you have non-stock suspension. the front will be very flush, and the rear will be slightly more aggressive than an ///m with stock wheels and tires. you'll need an alignment after your install as well.
05-06-2011, 08:42 PM | #5 |
Rep 409
front = 19" x 8.0" et29 (e89 225/35r19)
rear = 19" x 9.0" et40 (e89 255/30r19) also... note to OP... don't use runflats with these. some of the e89 wheels in 19" diameters have rear wheel cracking issues. check "z4-forum.com" for specifics. and remember, your rear brakes are going to look tiny. that is the only reason i didn't go for these myself, even though they are absolutely gorgeous.
05-06-2011, 10:01 PM | #6 |
Rep 2,736
Actually I'm planning to do a very special brake upgrade, and the rears I'm actually planning to retrofit the 330 performance brake setup with the BMW drilled rotors that should fill it up a little
05-06-2011, 10:48 PM | #7 | |
Rep 409
while i think that brake retrofit is a great idea, imo 19" wheels on the e46 also make the rear rotors look tiny on that car too. my 2 cents worth. do the brake retro either way. you can be our guiniea pig.
05-07-2011, 02:30 AM | #9 |
Turd in the Punch Bowl
19
Rep 239
Those look sweet... Hey "C".... When are you getting your tune and dynos done?? I am dying to see what number you get... Would love to hear your exhaust too!!!
05-07-2011, 04:35 PM | #10 | |
Rep 2,736
As far as the brakes go I've been working with another member on this forum to make this happen but it will be oh so hot when its done. And have been looking for a rim that will show it off nicley. The Brembos transformed my mini cooper s braking wise but the cost is still crazy so this will be quite something if it pans out. But I know what you guys mean when you speak of having a puny brake setup with big rims ...especially the open style ones. |
