      11-28-2019, 12:38 PM   #1
Reborn_
Drives: 2007 BMW Z4MC
Rogue Engineering Rear Shock Mount (RSM)
https://www.rogueengineering.com/Rog...E46_p_270.html
I've got a few questions for those who have installed these.
1.) For stock shocks or Bilstein B6, is that the standard 10mm?
2.) Which parts (Diagram) are replaced?
Much appreciated
      12-02-2019, 07:38 AM   #2
jhm5
Drives: X3 M40i, 440i, Z4 MR, 2002
It's been years since I installed these in my long ago sold Z3 M Coupe, but I believe the kit includes all you need. Best contact Rogue directly. They'll know what shocks fit what parts. Besides longevity, a key advantage, if you ever need to replace again, the nuts are reachable under the car. You won't have to remove a ton of interior trim to get to them.
Reborn_298.00
kaybat125.50
      12-02-2019, 06:28 PM   #3
BradZ4MC
B
Drives: Z4 M coupe
2005 BMW 330ci  [0.00]
2007 Z4 M Coupe  [7.00]
Much appreciated
It should replace parts 5-10. The mount will go in upside down for easy future access. Fairly easy to install.
If I remember right RE has good instructions with them.
Incase you are interested I am removing Bilstein PSS10 set up, Ground control camber plates and Rogue RSMs in the next month as I have just ordered MCS double adjustable dampers and race plates and spherical RSMs.
I will be selling it hopefully as a package.
Reborn_298.00
      12-03-2019, 08:07 AM   #4
Reborn_
Awesome, that is what I figured, thank you for confirming! I already bought a bunch of parts (excluding 5-10) so I'm all set, but I'm sure you will have no problem offloading those nice parts.
