      11-15-2019, 09:37 AM   #1
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
Flush the ABS System as Maintenance Routine?
Thought I'd post this as there seems to be varying thoughts. I know I've wondered if I was being remiss by not cycling the ABS during my every-other-year flush. This is from a BMW master tech with over 2 decades of experience.
"We dont normally bleed the abs module. The fluid goes from the frt and rear ports on the brake master through the abs module to the individual wheels. So it is getting flushed but there are some parts that won't be flushed as the valves are not being opened and closed unless they are activated thru the tester. You could go out and stomp on the brakes to activate the abs and then do your flush. I wouldn't worry about it. I have always done just regular flushes on all of my BMW's and never had a problem. That's what we do here at work"
So it seems cycling the ABS (e.g via INPA) is only needed if air gets in the system.
