      10-27-2017, 03:39 PM   #1
Z4JAC
Drives: 2007 Z4 Coupe 3.0Si
"P" remains lit....
So I was installing some new trim as well as an automatic shifter and I disconnected the shifter trim ring with the door open. I contacted Bimmian (manufacturer of the shifter) and they informed me that you're not supposed to disconnect anything with the doors open or you may interrupt the P-BUS?? Google searches indicate that if the P light remains lit, the car is technically not going into sleep mode.
Can anyone give me some information on the validity of these statements or if there is a way to reset it?
TIA
-Dan
      10-28-2017, 06:12 AM   #2
JCF
Drives: 07 Z4 M Coupe
You’ve checked all your connections, right? Is there a fuse you could pull? Alternatively, disconnecting the battery for a bit and reconnecting it should do it.
/// LED Lighting /// Pedal Haus M aluminum pedals and heel plate /// BMW logo puddle lights /// CF wrapped console /// LeatherZ MK4 console storage, armrests, door pulls /// ZHP illuminated shift knob /// BMW under seat storage /// Soundplicity III /// Stubby Antenna /// Eventuri Intake /// Tekcarbon CF valve cover /// Stromung exhaust /// Rogue Engineering Transmission Mounts ///3rd brake light blinker
