      07-13-2014, 11:58 PM   #1
nutzkicker617
nutzkicker617's Avatar
28
Drives: Z4 M Coupe
Found 2 small leaks from the engine
Found a leak coming from the big plug from underneath the engine.
Tried to look for a part number but couldn't find it on realoem.
Anyone know if I can take it out, and inspect during the next oil change or what size it is?
Or a part number etc
And also from the back passenger side corner of the valve cover. This leak started after I had my valves adjusted by Kaiv. I went back and checked that all the bolts were torqued down to 7lb/ft. Any else I can do?
Thanks in advance.
      07-14-2014, 12:06 AM   #2
dorifto88
Drives: 88 Nissan Pathfinder
Pretty sure that's the transmission drain plug, but I could be wrong
      07-14-2014, 01:13 AM   #3
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Thanks in advance.
I'm pretty sure the leak on the passenger side is from the valve cover gasket. I have the same leak after "Kaiv" did my valve adjustment last year...still have the minor leak. My next valve adjustment is due in approximately 15K, so I'll wait until then to replace it with the OE gasket next time. Other than having the gasket replaced, I'm not sure there's much else you can do. We need to tell "Kaiv" to stop using those gaskets!
      07-14-2014, 01:26 AM   #4
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
Looks more like the oil pain - I can partially see the oil level sensor in the picture as well as the oil pan center cover (where the oil pump pick up line goes)
OP...I don't see that plug in RealOEM either
      07-14-2014, 07:04 AM   #5
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
Thats the oil pan inspection plug. Its there so that you can remove it and snake in one of those camera probes if need be.
I had the same leak when I got my car. Drain the oil, remove plug, clean off, reinstall and torque. Unless its cracked or something (seems extremely unlikely) the problem should just be that its loose.
I wouldn't wait around to take care of it. When its loose, the engine vibration could cause it to back out the rest of the way, leading to no oil and a catastrophic failure.
      07-14-2014, 02:34 PM   #6
donoman
Rookie
33
Drives: 03 Z4 2.5i 5MT
Back side passenger corner might be CPV - constant pressure valve - oil can leak from there and wick up. I have the same leak. Supposedly very common on S54.
2003 Z4 2.5i
2013 FR-S
1990 911 C2
1983 Wife
      07-15-2014, 12:26 AM   #7
KevinC
your average JAMF
KevinC's Avatar
OP, your avatar is ready...
'21 M2 Comp
'19 Golf R
