06-23-2015, 12:00 AM | #1 |
Mechanical Engineer
96
Rep 1,025
Emergency Help Needed - Clutch Bleeding Problem
I was just finishing up my inspection II (did everything except for valve adjustment, thats next weekend) and have run into a major problem. If anyone can offer any suggestions, or if anyone in LA (I live in Pasadena) is in the mood to give me a hand for an hour, it would be a HUGE help.
I did a brake fluid flush and bled the brakes, and was bleeding the clutch. Unfortunately I tried to bleed the clutch with the brake reservoir about 2/3 full, which it turns out is a terrible idea on a BMW. The clutch and brake system both pull from the brake reservoir, however, the clutch line is dammed off inside the reservoir, and effectively pulls from right near the top. The result is that if you try to bleed the clutch with anything by a full reservoir, you fill up the clutch system with air. Thats what I did, fuck me. I have been trying and trying to bleed the clutch system, but since its pretty much full of air at this point I have not had any luck. The pedal has no resistance, even if you pump it a dozen times. I also tried reverse bleeding the system, by using an oil can to push fluid back up the bleeder, as shown here: I have no idea why, but that was also unsuccessful. When I tried pumping the fluid in, I couldn't get it to go in through the bleeder. Once I unscrewed it at all, I was just getting fluid leaking out near the threads, instead of going up into the system. Does anyone have any experience dealing with this? Anyone had this problem before? My next try is probably going to be to pulling the clutch slave and bleeding it manually by moving the piston back and forth, but I'm afraid of what new problem I'll run into. Anyone live nearby and have a pressure bleeder they would be willing to loan me? Or even better, be willing to give me a hand? I would be more than happy to give you a hand with any other maintenance or repair you need to do, including valve adjustment (I've done it half a dozen times now). Really running out of ideas at this point, someone please help. |
06-23-2015, 12:41 AM | #3 |
Rep 1,443
You should be good with the Motive bleeder. That's what I use. Very easy. When I bleed my clutch I empty 125mL to ensure a complete bleed. Run that much through and everything should be good to go. Good luck!
06-23-2015, 02:02 PM | #5 |
Mechanical Engineer
96
Rep 1,025
I thought of that, but I was a bit concerned about possibly bending the hard line that connects to the slave. It doesn't look like there is much/any slack.
06-23-2015, 07:50 PM | #6 | |
Roadie B4 Roady
Rep 118
Remus, ZHP, Stubby, H&R Coilovers
06-23-2015, 11:50 PM | #7 |
636
Rep 3,124
When I did my CDV delete I used a hose pincher to prevent catastrophic fluid loss, and did the swap as fast as I could.
I lost about 3 drops. Had the Wife unit pump the pedal and easily bled out the one tiny bubble that got in. About a year ago I installed Speed Bleeders and flushed the whole system solo in a little over an hour. Not sure how many uses the thread sealant on the Speed Bleeders is good for, so I bought a bottle. FWIW here's everything I bought for the royal flush, plus a "graduated" Gatorade bottle to measure how much I bled from each cylinder. Credit to Ron Stygar for finding the correct bleeders.
06-24-2015, 06:55 PM | #9 |
Bimmer Noob
30
Rep 566
Love my motive pressure bleeder.
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing, AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges |
06-24-2015, 08:42 PM | #10 |
Roadie B4 Roady
Rep 118
Has anyone used this? It's a bleeder bottle with a check valve.
http://www.turnermotorsport.com/p-17...ple-bleed.aspx
06-24-2015, 09:06 PM | #11 |
Rep 758
If you look at where the bleeder on the slave is with respect to the input line you get mostly direct flow from the line to the bleeder without much going through the cylinder itself. It can take a LOT of bleeding to get the air out because you only get a small fraction with each pump. The pressure bleeder should allow you to flow enough through there to get it fully bled.
Top Down 365
06-25-2015, 01:29 AM | #12 | |
Rep 195
06-25-2015, 07:22 AM | #13 |
Rep 11,667
There is a related thread where "shipkiller" has some good advice on this.
06-25-2015, 09:52 AM | #14 | ||
Roadie B4 Roady
Rep 118
06-25-2015, 11:20 AM | #15 |
Mechanical Engineer
96
Rep 1,025
Fixed.
Took the motive bleeder out of the shipping package, connected it to the brake reservoir, and was done in literally 10 minutes. Can't believe I managed to get so much aggravation out of what should only be a 5 minute job to being with. For anyone else doing this job; if you get any air in the clutch, put your tools down, order a pressure bleeder, and wait for it to come arrive. Everything in between is just a waste of time. |
06-25-2015, 12:04 PM | #16 |
Rep 11,667
^ thanks for the update, glad to hear that it was so simple
06-25-2015, 01:13 PM | #18 | |
636
Rep 3,124
The Speed Bleeders try and solve this by putting magical sealant on the threads. What's not clear to me yet is how many uses before the sealant needs to be replaced, which involves taking all the bleeders out, stripping, re-coating, and baking in the oven for a while. Glad you got it sorted. I'm sold. Speed Bleeders or not, I'm buying one. Do you have the info for the specific model you bought?
06-25-2015, 01:55 PM | #19 |
Mechanical Engineer
96
Rep 1,025
It didn't look like much, but air is highly compressible. Once the pressure bleeder was attached and pumped up, all the air inside can be compressed to a very small volume, so it doesn't look like much coming out.
06-25-2015, 02:00 PM | #20 | |
Mechanical Engineer
96
Rep 1,025
This is the one I bought: http://www.amazon.com/gp/product/B00...ilpage_o00_s00 The only extra feature I would like to have is the ability to pressurize it from an air compressor. I don't know if they sell one that does that or not, but maybe take a look on BavAuto before buying one. If you're just working on the brakes, I'm not at all convinced you need one of these, as I've never had a problem bleeding the brakes, even after pulling the calipers and introducing looks of air at that end. But if you mess up the clutch like I did, its pretty hard to beat. The reverse bleeding technique I tried makes a big mess, and I think you need the bleed screw set perfectly to get the fluid to travel back up the line, instead of around the threads and back out. |
06-25-2015, 05:12 PM | #21 |
636
Rep 3,124
Thanks. j(2h)^3
I'm due for another complete system flush in the fall. I also want to get attachments for my Ram and Ford trucks. I'm sure I'll get plenty of use out of it.
06-25-2015, 05:30 PM | #22 |
Mechanical Engineer
96
Rep 1,025
No problem.
Here's a list of the adapters they offer: http://motiveproducts.3dcartstores.c...ters_c_13.html |
