06-17-2015, 06:29 PM | #1 |
Rep 2,704
Garage jack/hoist
OK so being a weekend mechanic and DIYer I would like a safe way of lifting and lowering my Zed. Having unfortunately scraped the side sill recently due to the trolley jack slipping on the factory pads I went looking for a reasonably priced piece of equipment.
I came across this on my search. Any other options out there that others have used. Looking to spend around 1500
06-17-2015, 07:03 PM | #2 |
Rep 2,782
Have you considered Race Ramps?
06-17-2015, 07:06 PM | #3 |
Rep 2,704
Want to be able to remove the wheels so need to jack on the chassis
06-17-2015, 07:30 PM | #4 |
701
What about this? I think it's in the right price ballpark.
http://www.zpost.com/forums/showthread.php?t=439177 |
06-17-2015, 08:57 PM | #5 |
Rep 2,704
Thanks Finnegan, I knew I had seen something before but didn't come up in a search.
That one looks beefy. I do like the clear access the one I posted gives.
06-17-2015, 10:33 PM | #6 |
Rep 1,483
I didn't see how small this was until I watched this video. Kool product.
- Instagram ->@e91kiter |
06-18-2015, 04:45 AM | #8 |
Rep 1,443
Lift Stands are another excellent option. They're a bit expensive for what they are and a little hard to get due to the wait list but, in my opinion, they're better than anything up to a two/four post lift.
06-18-2015, 09:20 AM | #10 |
Rep 415
Goals
07 TiAG Coupe @Jroc561 |
06-18-2015, 09:31 AM | #11 | |
Rep 11,667
Do they lift, or are they stands after lifting with floor jack?
06-18-2015, 09:41 AM | #12 | |
Rep 415
Basically jack stands.
06-18-2015, 09:47 AM | #13 | |
Rep 11,667
theres enough clear space to get to the tranny etc for service. its actually pretty good for exhaust work as the beams give you something to rest the system on. It makes exhaust work an easy one man job. That said... There are other lifts similar to what you posted that lift higher that I would consider if I was buying a lift now. One of my main objectives was to work under the car w/o crawling on the floor, so a low lift wasnt on my radar at all.
06-18-2015, 11:24 AM | #15 |
Rep 1,443
You have to get the tires ~8" off the ground but then you can raise and lower there car another 6" front/back side to side any time you need to during a project. The Lift Stands were worth it just for doing my headers. I noticed the OP wants to be able to take the tires off so these may not be perfect but it's really very easy to toss jack stands under the front or rear or even just a corner if you need to. There's so much room under the car, it's so easy to raise and lower now, and I feel 100% safe working underneath for hours.
06-18-2015, 01:44 PM | #16 |
Rep 11,667
They look to be very well made as well.
06-18-2015, 03:55 PM | #17 |
Rep 1,031
Looks like there is a Canadian distributor for the Quick Jack.
http://www.babco.ca/Automotive-Equip...nger-QuickJack I like it, looks sturdy and could be useable in my tiny garage. Great find!
06-18-2015, 04:00 PM | #18 |
Rep 2,704
Asked Babco for a quote.
They came back with a tad over 1700 Canuck Bucks, taxes in, dropped at my door. Might treat myself before end of season.
06-18-2015, 04:10 PM | #19 |
Rep 18,724
With the budget you have, Atlas makes a 8,000lb two-post list made for 9' garage ceiling. I'd get that instead.
My 2 cents.
06-18-2015, 04:12 PM | #20 |
Rep 2,704
That would be my choice too if I had a taller garage, unfortunately only 8' ceiling.
06-18-2015, 04:17 PM | #21 | |
Rep 18,724
I'm sure you'll enjoy whatever you end up with. Good luck.
06-18-2015, 04:56 PM | #22 | |
Rep 11,667
The only problem with 2 posters is if you use the space for parking the car, the posts are often in the way for getting in & out of the car. They are also in the way when working around the car such as when detailing
