      10-10-2013, 06:57 PM   #1
jeebus87
Drives: '11 atacama yellow Z4 35i
19x9.5 et33 on z4 3.0si?
Just need a quick question answered for some rims I am considering: will the above offset fit in the rear without rubbing?
      10-11-2013, 08:11 AM   #2
3002 tii
3002 tii's Avatar
2280
It depends on the tire you plan to run. I ran a 18x9.5 et35 on a lowered car with 255/35 and it didn't rub but if you plan to ride wider or tall profile it may. You should be prepared to roll the fenders worst case.
Follow for latest mods
      10-11-2013, 09:16 AM   #3
jeebus87
According to the seller, the tires appear to be 265/35. Thanks for the reply!
      10-11-2013, 09:40 AM   #4
3002 tii
3002 tii's Avatar
2280
Will likely rub, a 265/35-19 is over 26". Stock height of 255/35-18 is 25". That 1" is a lot... you'd be better off running a 255/30 or 265/30-19.
      10-11-2013, 10:44 AM   #5
M-Power M3
Retrograde
M-Power M3's Avatar
18
Drives: Bagged Z4
+1 you're gonna want a 30 sidewall. The offsets will be fine with the above mentioned tires. I was running 19x10 +36 and could air down and tuck almost to rim without rubbing.
