      07-31-2013, 01:04 PM   #1
mpower1226
Drives: Audi TT
17 inch APEX ARC rims..
What would be the ideal offset and tire size for 17inch Apex rims? provided that the mc is on stock suspension and not changing the alignment specs(and no fender rolling).
I am looking for a 17inch setup for track use and also love the extra meaty look on side profile for mc.
      07-31-2013, 11:14 PM   #2
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
Subscribed... I'm considering something similar
      07-31-2013, 11:38 PM   #3
seank
enthusiast
seank's Avatar
48
Excellent choice.
      08-01-2013, 01:37 AM   #4
beta
Drives: 2006 M Roadster
Did you see: new 17" track setup- Apex Arc-8's.
On stock suspension, without added camber, etc. you probably can't go as wide as that thread 9.5/10.5. So probably around:
Front
17x8.5 et40 with a 5mm spacer or
17x9 et30
Rear
17x9.5 et35 with a 10mm spacer or
17x10 et25
      08-01-2013, 02:41 AM   #5
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
If you're willing to spend 20 bucks on Turner camber washer/spacer + a proper alignment (anywhere between $80-$120), you can get -2.5 camber in the front and run 9.5 +35 with a 10mm spacer with 265 width tires. Its what i'm currently running with no rubbing whatsoever. This is with hard driving at the track will full compression.
      08-01-2013, 01:24 PM   #6
mpower1226
Drives: Audi TT
Front
17x9 et30
Rear
17x10 et25
Any tiresize recommandation for above spec'd rims?
I am assuming above size will not rub with stock suspension?
      09-22-2013, 08:08 PM   #7
intoflatlines
Did you choose this combo, and if so, what tires/sizes did you get?
      11-02-2013, 12:19 PM   #8
drbvac
drbvac's Avatar
Drives: 2006 BMW M COUPE
Originally Posted by mpower1226 View Post
Front
17x9 et30
Rear
17x10 et25
I would be interested as well BB
2006 M COUPE - 380 total production, 1 of 40Imola Red produced for NA , ESS 455 Supercharger, Speedhut Gauges, VPM CLS wheels, 19" Hancooks, Stromung Exhaust, Carbon fibre accessories and black and white badging,
