02-21-2018, 07:14 AM | #331 | |
Rep 912
Depending on how low you are, camber is the solution. It won't have to be dramatic as the other guys have mentioned. |
02-23-2018, 09:54 PM | #332 |
Rep 2
Checking on fitment w some 19x8.5 et35, 19x9.5 et33 w standard suspension on 3.0i. Also any advice on tire size would be appreciated. Should there be any rub w these? Thanks in advance!!
02-24-2018, 08:46 PM | #333 |
Rep 879
I wish there was a fitment fairy because offsets, tire specs (rounded vs square) and lowering confuse me to no end. I have et40 front and et42 rear 19x8.5 235/35 with lots of room but I'm really low on h&r coilover
03-01-2018, 08:24 AM | #334 |
Rep 509
I had 235/35-19 on 8,5 ET34 in front. Michelin PSS.
Rubbed like crazy. Swapped to PSS 225/35-19 on same wheel. No rubbing. Even when pushed at the track. No adjustable camber plates, only pulled the pins from the OEM guide supports. Running OEM shocks and H&R springs.
My Hellrot '06 BMW Z4 3.0si Coupe and My Mineral Grey '14 F30 (sold) New daily: Sunset Orange 330E G20 Instagram: @StigJ77 & @bmwe86driver |
3GFX722.50 |
04-03-2018, 04:08 PM | #335 |
Rep 12
Hello all I'm a newb on here, and recently purchased my 03 Z4 manual tranny 2.5l Grey as a project sunny weekender car. (completely stock not lowered) I have an opportunity to purchase a used set of CSL style reps matte black but I'm a little concerned as to the offset and fitment on the rears. Strangely enough the guy say's he doesn't have time to allow me to try the fitment as he's selling for his dad and letting go really cheap. Here's the specs your expertise would be most appreciated, the rears are the concern:
19" x 8.5" +35 Offset with 235/35/19 fronts 19" x 10" +33 Offset with 265/30/19 rears ( 10" WIDTH!!! +33MM OFFSET) Last edited by InterMstr; 04-03-2018 at 04:50 PM.. |
04-04-2018, 08:57 PM | #336 | |
Rep 12,567
04-05-2018, 06:30 AM | #337 |
Rep 912
If you are going for a show car look with LOTS of camber, they may fit but you will most likely rub unless you roll/pull the fenders. Anything can be done, it depends on what you're willing to go through with.
Your rears will stick out of the car 7mm more than my setup, I think with HEAVY rear camber it can be done. I've run a 9.5" rim on a 32 offset. Last edited by 3GFX; 04-05-2018 at 06:37 AM.. |
04-06-2018, 01:40 AM | #338 | |
Rep 509
04-06-2018, 07:04 AM | #339 |
Rep 912
I honestly think if they decide to run more than 2.5 deg of camber, it may work. Tire won't last long, but it might look sick.
04-09-2018, 12:23 AM | #340 |
Rep 12
3002tii, 3GFX, and StigJ, thanks for the response, I very much appreciate it, as usual I was swept up by the deal and not the reality of proper fitment, so I will continue my search. Cheers!
06-01-2018, 04:29 AM | #341 |
Rep 27
Hi need advice. I have 2007 z4 3.0si sport. Will these wheels/tires fit?
Front - 18x8.5 ET 38 with Ventus V2 Evo2 245/40ZR18 and new TPMS Rear - 18x10 ET 25 with Ventus V2 Evo2 275/35ZR1?? Will they fit? |
06-05-2018, 12:26 PM | #342 |
1821
Rep 5,337
Fit? Yes. Work? Depending on your definition.
06-11-2018, 02:05 AM | #343 | |
Rep 509
Rears are too low offset in addition to a little too wide tires. I have 10" with 265 ET41. The ones you are considering will stick out 16mm more than mine. I had a tiny rubbing on my Michelin PS4S at the racetrack. On daily basis its all good.
3GFX722.50 |
06-17-2018, 04:43 PM | #345 |
instagram : https://www.instagram.com/markos_z4/
64
Rep 71
bmw z4 coupe 3.0si
20 inch Barracuda voltec T6 black chrome INOX LIP FRONT: 235/35/20' ET40 wide 9J REAR : 285/25/20' ET40 wide 10,0J OEM M-sport suspension not lowerd no rubbing
follow me on instagram:www.instagram.com/markos_z4/
WideEVO37.50 |
08-03-2018, 08:51 PM | #347 |
Rep 1
2008 Z4 Coupe 30 si stock and never raced
I’m thinking about replacing my wheels and tires.
Will these work on my Z4 Coupe? Wheels and tires from BMW 435i M sport pkg with only 100 miles on them. Staggered set 2 Bridgestone Potenza 5001 run flats 255/40r18 2 Bridgestone Potenza 5001 run flats 225/45r18 Thanks for the help. Scott |
08-06-2018, 07:19 AM | #348 | |
Rep 912
Based on the tire width, it will all come down to your offset of the rim to know if you will rub somewhere. Judging by the widths you should have plenty of room on the sides. Having said that the tires on the wheels have an aspect ratio of 5 great than stock. So your diameter and circumference will be larger by that amount. Will it fit? Most likely. They could fill our your arches better if you're not lowered because the overall diameters are larger. You car will be slightly higher off the ground as well. Will your speedometer read wrong? Most definitely. Read more of the thread and use this tool: https://www.1010tires.com/Tools/Tire-Size-Calculator |
09-28-2018, 10:27 AM | #349 |
Rep 70
Talking about tight fitment! These wheels came off my non running E46 M3.
Enkreuz HS10 F: 19x8.5 235/35 R: 19x10 295/30 Unsure of the offset though since these are 3piece wheels
Always evolving
09-28-2018, 11:39 AM | #350 |
Rep 912
09-28-2018, 12:00 PM | #351 | |
Rep 70
Always evolving
