12-08-2022, 02:02 PM | #1 |
Rep 45
afe Intake Install Question
On the main housing, there is a hole at the bottom that looks like it should align with a bolt on the frame of the car that holds a rubber piece to support the stock airbox. However, the hole does not line up with the bolt (see attached image). It is off by 2 inches or so. All the other bolts line up with their respective holes. I know there are different versions of the intake for the other models of this generation. Could I have been delivered the wrong version of the housing?
12-08-2022, 03:00 PM | #2 |
Rep 783
I ran into a similar problem, you need to remove the rubber bumper, loosen off all the other mounting screws and see if you can persuaded the sheet metal to fit.
I stretched it over, it's certainly not ideal but the top still fits nicely.
2008 E86 M coupe
12-08-2022, 09:21 PM | #3 |
Rep 45
Thanks for your response. Everything still fits great. It’s more of an annoyance of having the hole not lined up. There wasn’t a nut included to screw over that bolt so I guess it isn’t really a big deal.
I kept the rubber piece because it’s supposed to help quell the vibrating metal sound that some folks have experienced. |
grannyknot953.00 |
