      03-02-2012, 11:22 PM   #1
gtMc
gtMc's Avatar
21
Drives: '08 MC
'03 e39 m sport  [0.00]
'08 mc  [0.00]
WTB E85 Amplifier from top hifi
Someone out there with a Roadie must have upgraded their sound system and still have the stock amp lying around. looking for part #65129125751 or part #65129138102, but most importantly it needs to have come from a Roadie with top hifi. Not out of a coupe. Its a coding issue. Im running an experiment, willing to pay anything reasonable. Thanks.
      03-03-2012, 12:46 AM   #2
BU Z4
Drives: Big & Small
whats reasonable for a $1200 amp
      03-03-2012, 09:00 AM   #3
gtMc
gtMc's Avatar
21
Drives: '08 MC
'08 mc  [0.00]
Open to suggestions here. Problem is that this project/experiment I am trying is worth ~$300 to me. BUT, I am not looking to pick anyone off, this needs to be fair for seller.
If consensus is that a used amp is worth more like $800, then maybe I need to try and sell my perfectly good amp out of my coupe first, for $500. (and if the buyer is an e85 owner, then it'd cost that person another +$160 or so to have it recoded to their car).
Perhaps I need to offer up a swap instead with me paying a premium for it. Just hoping someone had one laying around they'd be happy to punt on the cheapey. Shoulda labeled this thread a 'Feeler'.
      03-03-2012, 09:02 AM   #4
gtMc
gtMc's Avatar
21
Drives: '08 MC
'08 mc  [0.00]
this post in the audio section is the other way I am trying to accomplish this:
http://www.zpost.com/forums/showthread.php?t=656683
      03-03-2012, 01:44 PM   #5
gtMc
gtMc's Avatar
21
Drives: '08 MC
'08 mc  [0.00]
Swap arrangment has been found. All set - thanks all!
      03-03-2012, 01:57 PM   #6
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
Greg, keep this thread open as depending on your results, I would like to get this done!
The Raspinator
      03-03-2012, 02:04 PM   #7
Hoa
No_Country
513
Drives: BMW
i have both m coupe and m roadster. the audio in the m coupe sucks as well. the roadster has a lot more bass. i might have to find someone with navi and do the same like you. too bad my roadster doesnt have navi. if it does, ill swap it with my coupe
      03-03-2012, 02:45 PM   #8
gtMc
gtMc's Avatar
21
Drives: '08 MC
'08 mc  [0.00]
Will do. Of course, you will get to experience the difference first hand. let you know when it arrives, hopefully next weekend.
      03-03-2012, 02:51 PM   #9
gtMc
gtMc's Avatar
21
Drives: '08 MC
'08 mc  [0.00]
You might still do the swap. Check out the thread "working with Carver Subs", he is in the exact same situation as you with his cars, and he did the swap. According to him, giving up the Equilizer in the Nav equipped coupe by swapping his non-nav e85 amp into it, was still a "1000%" improvement over the orig coupe coded amp even though he no longer can use the EQ. Then he took his e85 to the dealer, with his e86 amp in it, and they recoded the amp back to the e85. End result: 2 cars with the much better "e85" sound, even though he cant use the EQ in his nav equipped e86.
      03-11-2012, 07:47 PM   #10
gtMc
gtMc's Avatar
21
Drives: '08 MC
'08 mc  [0.00]
Update as promised... The Swap worked great! I updated this thread under the Audio section with details:
