      05-27-2010, 12:34 PM   #1
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
Clutch bleeding tool question?
Just flushed my brakes and clutch using a pressure bleeder. Flushed the fluid out of the clutch with pressure till new fluid started to exit the tube. How important is it to use the "special" clutch bleeding tool from BMW or Bav auto? Will it make much difference? My clutch pedal feels the same and shifts fine after the bleed. I have noticed however that I have a harder time getting the tires to break loose on a quick 1-2 shift. Wondering if this may have something to do with air in the clutch from the sideways mounted bleed valve.
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
      05-27-2010, 12:56 PM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I've been wondering about this as well.
      05-27-2010, 01:05 PM   #3
cloud8r
Member BMW CCA Los Angeles
cloud8r's Avatar
Drives: 2022 M8 GC Comp
2018 BMW M4  [0.00]
ditto
Current Rides:
2022 ///M8 GC Comp
Much enjoyed:
2018 ///M4 ZCP || 2014 ///M5 ZCP || 2011.5 ///M3 Sedan || 2007 ///M Coupe || 2008 550i Sport || 2006 ///M3 ZCP || 2008 X3 3.0si || 2006 325i || 2003 Z4 3.0 Roadster || 2003 330ci || 2002 325i
      05-27-2010, 01:32 PM   #4
trsbmw
deft danish devil
Drives: BSM E86 M-Cp, LMB 335d M-Sport
2007 Z4 M Coupe  [0.00]
The tool is not necessary on the z4m. It is only necessary on the cars where the bleed screw is on the bottom of the slave cylinder.
      05-27-2010, 01:49 PM   #5
mousitch
Dark Sider
mousitch's Avatar
129
This has a pretty interesting bleed method in it
      05-27-2010, 02:07 PM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^nice find
      05-27-2010, 02:31 PM   #7
mousitch
Dark Sider
mousitch's Avatar
129
Since my warranty ran out I might try this when I remove my modified CDV. Not sure how it would work as the line is full of fluid. Just really interested in the slave cylinder piston being bled.
      05-27-2010, 02:41 PM   #8
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
This makes total sense to push from the bottom.
Should work just fine, you just won't get much air, just new fluid moving through.
I'll be bleeding my brakes in a couple of weeks, I'll give this a try as well.
