      11-20-2008, 11:01 AM   #1
pungo
pungo's Avatar
What fuse is for the headlight washers?
I have a 2007 with headlight washers and want to disable them since the other day all it did was soak the entire hood of my clean car with fluid. I looked at the card in the the fuse panel and it showed symbols that looked like headlight washer and windshield washer with fuse number 13, 38 & 40. I pulled 13 which took away steering wheel controls. I now have 38 out and I'll see what that does. If someone knows for sure, please post the fuse number. I just hope that this fuse doesn't effect any other operations except the headlight washers.
      11-21-2008, 07:58 AM   #2
EricMCoupe
Drives: none
Should be Fuse # 40 -- see chart below...
I'll be disabling mine as well just as soon as the dealer gets around to replacing my missing headlight washer cap (but that's another story).
      11-21-2008, 08:45 AM   #3
Starscream
Starscream's Avatar
Easier alternative,
pop the hood, In the headlight washer tank you will see 2 pumps plugged in,
The one closest the front bumper/radiator is the one for the headlight jets, Just unplug it,
No error messages on the dash and its easier to get to than the fuse option,
thats what I did on mine, Hate those little things
Imola Red Roadster
      11-21-2008, 02:08 PM   #4
pungo
pungo's Avatar
EricMCoupe- Thanks for the fuse chart, that should come in handy. I printed it out and will keep it in the closebox, I think it might even fit in there
Originally Posted by Starscream View Post
Easier alternative,
Do you know if unplugging power to the pump stops the jets from raising up, even if they don't spray fluid? I'm afraid of loosing the painted washer cover. My guess is that fuse 40 will prevent them from raising, but pulling the pump power won't. Hopefully fuse 40 will turn off power to both the pump and the raising mechanism. Wish I had a schematic to see for sure.
      11-25-2013, 11:43 AM   #5
S2000
Drives: E86 Z4M, E60 M5, E92 M3
I removed Fuse #40, Green 30A.
It works...Thanks.
I have lost two covers ..part is cheap but the paint job is $100 at body shop.
      11-25-2013, 12:11 PM   #6
StickMon
StickMon's Avatar
Drives: 2006 MR
Water pressure raises the jets, just like pop-up lawn sprinklers.
Either unplugging the pump or removing the fuse will stop them.
      11-25-2013, 05:04 PM   #7
pungo
pungo's Avatar
Holly 5 year old post resurrected.....
      11-26-2013, 01:19 AM   #8
StickMon
StickMon's Avatar
Drives: 2006 MR
      12-04-2013, 07:40 PM   #9
AmmarYasirA
Ammar
AmmarYasirA's Avatar
Drives: a lot
ermmmmm, so I dont know why I did this.... but I put the fuse back in and now it wont spray the headlights anymore
2018 F150 Platinum - Black/Black - Leveled on 34's - DD
      12-04-2013, 07:47 PM   #10
StickMon
StickMon's Avatar
Drives: 2006 MR
It only sprays them every 5 or so times that you use the windshield washer.
Try some more.
Then be sorry you did when they break
      12-04-2013, 08:05 PM   #11
AmmarYasirA
Ammar
Drives: a lot
Try some more.
Ill try some more, my regular windshield pump is screwed too... Ill try the fuse on that one too. But I feel like the problem is a little deeper than a little fuse.
      12-04-2013, 11:14 PM   #12
StickMon
StickMon's Avatar
Drives: 2006 MR
Pumps going out is a common problem.
Usual symptom is a puddle under the car.
Cheap and easy to replace.
      12-04-2013, 11:40 PM   #13
AmmarYasirA
Ammar
Drives: a lot
Makes me feel good haha. The word "cheap" when dealing with any German car is good news.
