      08-02-2017, 10:39 PM   #67
onebluemcm
onebluemcm's Avatar
42
Drives: '07 Z4MC
Got all the photos hosted somewhere that won't hijack them like Photobucket did for 3rd party hosting. Took a while but they are all embedded, and I made an update in the initial post. Have fun with it, hope this is helpful.
<img src=http://i284.photobucket.com/albums/ll30/onebluemcm/RG63_08-1-1.jpg border=0 alt= />
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=|
Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo)
RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint
inTgr8r2431.50
SaltyNC369.50
      08-03-2017, 11:37 AM   #68
nutzkicker617
nutzkicker617's Avatar
28
Drives: Z4 M Coupe
Thanks!
      08-03-2017, 12:48 PM   #69
PLCZ4MC
Proud E86M Owner
PLCZ4MC's Avatar
Thank you so much for fixing the photos. This treat is a huge help to those interest in installing this short shifter.
      09-14-2017, 02:25 PM   #70
PLCZ4MC
Proud E86M Owner
PLCZ4MC's Avatar
Nuuuu
Photos don't work again x-x
2007 Z4///M Coupe Monaco Blue (Weekend + Track)
2018 S1000RR San Marino Blue Wrap (Weekend + Commute)
2016 Honda CR-Z EX Jet Black (Daily Commute)
2008 Kawasaki ZX6R Plasma Blue (SOLD)
2008 Z4///M Roadster Space Gray (SOLD)
      08-06-2018, 10:33 PM   #71
onebluemcm
onebluemcm's Avatar
42
Drives: '07 Z4MC
An hour and a half later, I got all the pics fixed.....again....holy shiit, I took a lot of photos and am long winded.
It's funny, I did this job and this documentation of the work before we had kids. Now, were I to do it again, I would have had 1/10th the photos, and the job would have taken 10x as long.
Update on the shifter, well nothing to update, it's still as awesome an upgrade as it was at first, definitely one of the very best things a person can do with a Z4M or E46 M3.
      08-07-2018, 04:35 AM   #72
wdb
dances with roads
wdb's Avatar
4732
This forum member thanks you for doing it! Great shots. And, kids keep you young. The payback comes later though.
      10-26-2018, 07:30 PM   #73
nutzkicker617
28
Drives: Z4 M Coupe
Is the kit supposed to come with a new circlip? My set that I purchased from a forum member did not have the clip of satan.
Also, are people replacing the front carrier bushings with delrin bushings or are new stockers good enough?
      04-26-2020, 04:34 PM   #74
wdb
dances with roads
wdb's Avatar
4732
Resurrecting this thread. I just did this install, but since I was pulling the gearbox I did things a bit differently. Reading over the original instructions here, there are a couple of things I'd modify, and a couple I'd add -- perhaps due to Ron adding bits to the newer kits.
An alternative to custom tooling for the exhaust work is to disconnect the back end of the exhaust at the mufflers, perhaps even dropping the mufflers as well (I left them in place). MUCH easier access to the bolts in that location. It does mean dropping the rear stress plate and braces but those go off and on pretty quickly. The bolts are supposed to be replaced but a lot of people reuse them 1 or 2 times before replacing. The reason they're supposed to be replaced is because they're torqued to 59Nm AND THEN another 90 degrees. They stretch. Be prepared with leverage if you choose this option.
I was able to remove the shift arm with the gear lever in place, without removing the rear mount. I would try that first before fabricating tools to remove the rear mount.
I had the gearbox on the bench for removal of the brass "spawn of satan" connector to the shift rod that goes into the gearbox. It. Still. Was. A. Bitch. I don't know how I'd do it in the car! But one idea might be to drop the driveshaft center bearing, put a jack under the gearbox, then remove the 4 nuts holding the transmission mount. Lower slowly, revel in the extra accessibility. Note that the center bearing needs to be preloaded upon reinstallation; push the center bearing mount towards the gearbox a couple of millimeters before tightening it down.
The kit I received included a new, Ron-made connecting rod between the lever and the gearbox selector shaft. It includes lovely bronze bushes which improve precision even more, and it eliminates all the stuff about modifying washers. Oh and it uses C-clips instead of devil's clips.
I also received delrin bushings for the front of the shift arm, where it connects to the gearbox. They also have lovely bronze bushes, and are a tight fit up there -- both into the gearbox ears and for getting the pins back in. I used a little bit of synthetic grease to help get the front of the arm started, then I used an aligning tool with a 90 degree bend to line up the holes. It is a bit fiddly. But worth it.
I installed a new rear mount before wiggling the shifter arm + lever back in. Kinda wish I had reviewed this first. I think reassembly would have been easier. So, before reinstallation, assemble the arm and the rear mount as described here. The rear mount comes out pretty easily without special tools once the shift arm is out of the way.
3002 tii2284.50
