      05-26-2017, 05:18 PM   #1
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
Any members with Delrin shifter bushings?
Has anyone changed the worn out oem rubber shifter bushings for aftermarket solution like Delrin plastic bushings? I am looking to get rid of the slop in the my Z4. I just wanted to know if anyone has done this before on the Z4 chassis. I have seen other bmw chassis forum members have good things to say about them but doesnt seem like any z4 owners have done this. No i dont need any of those aftermarket short shifter kits, I prefer the stock shifter lever.
      05-29-2017, 09:12 PM   #2
drewski429
Drives: 2006 Z4 3.0si Sport 6MT
About to install ECS Tuning delrin shift kit
Bought these a few weeks ago when I ordered both DISA valves, just got the intake back together and drove it today, next project is replacing the A/C compressor, so I'll be under there to install the shift refresh kit anyway... I'll post updates once I get the car off my lift and drive around. It should feel great since I just got my ZHP knob.
https://www.ecstuning.com/b-ecs-part...17367ecs01akt/
I DIY literally everything but laser alignments and I don't feel comfortable compressing springs to do suspension myself... and I don't mount my own tires...
New AC kit incl. expansion valve, filter drier and o-rings was a steal at $600 at buyautoparts.com
Most of what I buy for my Z4 comes from ECS Tuning except the red hot handmade coil packs from bavauto.com - makes a HUGE difference, highly recommend with NGK plugs and K&N drop-in filter, revs drop fast for quick shifting https://www.bavauto.com/5005-6
      05-31-2017, 06:19 PM   #3
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
Nice let us know how the delrin shifter bushings go! Advice and comments are both appreciated! Those are the exact ones i was eyeing a week ago! Ecs is my go to for any parts for my car too! Very fantastic you do all your own work! I also DIY everything too, aswell as most of the forum member are pretty competent to diy and save a $ or two too! I have that bmw starter kit too! Zhp shift knob, k&n filter, ngk iridium spark plugs only thing that differs is that I bought oem bosch coils!
      07-24-2017, 10:29 AM   #4
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
Any one else?
      07-29-2017, 10:05 AM   #5
Shutterspeed
Shutterspeed's Avatar
Drives: 2008 Z4 M Coupe
I bought them the same time as I bought the UUC double shear selector rod but I haven't installed either yet.
2008 BMW Z4M Coupe (BLTZKRG)
2013 Scion FRS (Kamikze) Sold
      09-04-2017, 01:30 AM   #6
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
Cool! Just bought some delrin shifter bushings, rear shifter bushing, misc pieces on the shifter, guibo, and center support bearing, going to refresh the beat drivetrain pieces
      10-01-2017, 06:51 PM   #7
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
So over the weekend I installed the delrin front shifter bushing, rear shifter bushing mount, foam shifter attachment, and replaced all the hardware on the shifter. My conclusion is that the shifting is much more direct and firm compared to the old worn hardware/bushings! Would recommend if you want a firmer shifting feel without spending $$$$ for a SSK!
      11-07-2020, 11:36 PM   #8
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
Update, recently went to a chassis mounted PSDesigns UK race short shifter with titanium shift knob. The best part is that I didnt have to trim or cut any of the interior shifter surround to fit the shifter assembly! Ouweee! This thing is a dream to row gears in! Super solid and super reassuring the shifter goes into each gear!
pyshin110.50
      11-12-2020, 11:09 AM   #9
Steeler
Steeler's Avatar
2428
Looks good.
Did you take any photos of the connection to the chassis?
Did you change out the shifter rod to the transmission as well?
TRiCC264.50
      11-13-2020, 01:32 AM   #10
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
Originally Posted by dbarton62 View Post
Looks good.
It shifts/feels good! No didnt take any pictures of the chassis mount with the shifter assembly installed using the provided hardware with blue thread locker and bigger diameter washers. I used the stock oem single shear selector rod.
Steeler2427.50
      03-26-2022, 02:52 PM   #11
John_Romanos
Drives: BMW Z4 E85
Looks good.
Do you have a link to the bushings and stuff? I'm just a tad confused on all the stuff
Do I have to go under the car to replace the bushings?
