11-12-2011, 06:39 AM | #1 |
Flycaster
Rep 103
Can changing the engine air filte make such a difference?
My 2005 Z4 2.5i has 25K miles. According to the OBC, lately I've been getting about 20 mpg in mostly city type driving. This is a drop in mph from around 22-23 mph. I just replaced the the filter with an OEM Mann filter and the mpg has gone up to 24-25 mph. Is this possible, or am I dreaming?
11-12-2011, 10:34 AM | #2 |
6 of Diamonds (ret)
82
Rep 566
Not to be crititcal, but kinda think it might have been more you being aware of the new filter and driving inadvertantly easier. If you really want to get scientific you need a measuring device/equipment that will ultimately allow you to calculate SCFM air flow of each. whichever one flows the most air will give you a little better milage, all other things being the same. Could be done, but time, money, expertise, etc. A better test might be to get it on a stretch of Highway, with new and old filters, under CC. Same conditions, same test.
Personally, I've never sweated city mpg's. Its hyper-dependant on traffic volume, route, traffic lights, etc. Just cant shine mpg consistently in the city. But its not a Prius, and hopefully thats why you bought it. Put the top down, shades on, and roll with it.
2007 Z4Si(gone)
Couple E30 Verts (DD) 2003 330i 2011 E93 335is - current fav |
11-12-2011, 10:38 AM | #3 |
instagram 997turbotom
279
Rep 7,377
depends on how long you've been keeping track of your mileage. If you measure it yourself not using the OBC, do a few weeks for a more accurate number
11-12-2011, 11:15 AM | #4 |
Rep 273
To answer your original question - yes, it's possible. Depending on how dirty the filter was that you replaced, it can have a significant effect on both engine performance and fuel economy.
11-12-2011, 01:25 PM | #5 |
Flycaster
Rep 103
Yeah, that's what I was thinking... Also, although the OBC is not the most accurate way to measure these things, if my mpg stays in the 24 mpg range, I'll still have a pretty good idea that the new filter did the trick. BTW, my driving manner hasn't changed since the filter went in.
11-12-2011, 04:30 PM | #6 |
Rep 29
it is entirely possible to notice better mileage with the clean filter. I notice the same type of thing right after I have new plugs installed - maybe a better more efficient spark that ignites more fully and eliminates wasted fuel.
I think those are certainly possible. Although I sometimes feel like the car is faster after a very good wash and wax - less drag? |
11-12-2011, 08:17 PM | #7 |
Rep 151
I constantly tested my mpg after switching from a used/slightly dirty OEM filter to a K&N high-flow filter and did see a gain of 4-5 mpgs (At sustained freeway speeds, allways using same fuel).
11-13-2011, 04:36 AM | #9 |
Flycaster
Rep 103
Not to burst any bubbles, but I have read that the K/N filters really don't do anything to boost HP; although, mpg may get better. And, BTW, remember that i use a relatively cheap Mann OEM filter...nothing fancy.
11-13-2011, 07:15 AM | #10 | |
Rep 2,138
Drives: Me
http://www.shipkiller.com/AirFilters.html I just put a Mahle (also OEM) in the ///M this weekend. AdvanceAuto has them cheaper than the dealer. I change my filter every 10K miles. |
11-13-2011, 01:42 PM | #11 |
Rep 483
I change mine every 10k or so, but I also take it out and use the shop vac to vacuum the dirty side of the out. I usually get lots of lint and leaf particles. Then I use the air gun (on stun not kill) to spray from the clean side down. Lastly I use the shop vac crevice tool to vacuum out the sand and crap that's collected at the bottom of the airbox.
I've tracked every single fill-up since I bought the car with aCar for Android: Average MPG is 26.726 with a max of 30.772. Using Sport mode or lots of stop and go traffic I'll have a tank of around 24MPG. I just got new non-runflat tires, so we'll see how MPG changes. |
11-13-2011, 03:47 PM | #12 |
Rep 1,001
11-13-2011, 09:20 PM | #14 |
Rocket Scientist
Rep 72
Drives: '08 M Roadster
I'm considering getting a couple of K&N air filters so I always have a clean one ready. The best mpg I've seen since I bought my ///M this past summer was 29 on the interstate. Now during my weekly commutes in NoVA, it's down to 21.8. I'm hoping the Inspection 1 it's going under right now will bring it back to 24. Still pretty darn good for a hi-performance I6!
2008 ///M Roadster
03-14-2014, 12:48 PM | #15 |
Rep 1
Hi all,
I've just joined the forum (not trying to hijack the thread at all!) so thought I'd say 'hi' and add to this thread. I bought my 2.5i Z4 Roadster (2007) from BMW Park Lane here in London - for those outside of the UK, this is the only dealership (to my knowledge) that is owned directly by BMW UK, and not a franchise. Anyhow, when I checked my air filter, it seemed a little worse for wear and so after much deliberation over a K&N filter, I went for a Mahle LX-1250 filter. Having fitted the part, all seems well and if anything, the Z feels sharper in throttle response and sounds as though its 'asthma' has been cured. Disappointingly, it seems the air filter wasn't changed prior to buying the car (I've attached a comparison photo at; http://goo.gl/HxoGBZ ) - any advice as to anything else they may have skimped on? Many thanks in advance! |
03-17-2014, 07:38 AM | #16 | |
Mechanical Engineer
96
Rep 1,025
