      01-14-2013, 02:10 PM   #1
snowmirage
Drives: 2003 BMW Z4 3.0i
HID / Non-HID Headlights How to tell?
I've been considering a set of the lights mentioned in this thread
http://www.zpost.com/forums/showthre...ghlight=spyder
There are HID
and
non-HID versions
( HID = high intensity discharge for anyone like who needed their memory refreshed)
From what I can gather the E85 Z4 could come with HID or non-HID headlights from the factory? If so what was the determining factor? Did just the Z4M have HID headlighs? Was it part of the face lift in the later years? A factory option?
I am also getting the impression that if you have non-HID lights you can't simply blot on a set of HID lights correct? And I'm under the impression that its due to more than just a different physical plug for each headlight.
I'm fairly confident that my 2003 Z4 3.0i has non-HID lights but I am basing that mostly on the fact that they don't seem to provide much light.
Can I tell for sure based on year or by inspection?
Just wanted to make sure I am understanding correctly before spending the money, and I hadn't seen it covered specifically in the other threads I've read.
      01-14-2013, 03:53 PM   #2
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6337
turn on your car and see if they are HID (they will look blue and color change into a white color)...if you hjave a 3.0 it probbaly has HID. the headlights you are planning on buying are far worse quality than your oem units
instagram: @ dubsesd
      01-16-2013, 10:52 AM   #3
SwissArmy
Why so serious?
SwissArmy's Avatar
Drives: BMW Z4; BMW X5; BMW 733
I had mine determined using my VIN number because I was in the same boat as you, and was considering the exact same set of headlights. I decided against getting the cheap ones. I am still using my stock headlights, and plan on getting custom headlights this summer.
Stay away from those headlights
      01-16-2013, 03:46 PM   #4
E85fan
Drives: 2004 Titanium Silver Z4
Where did you check with your vin. I'm also interested in checking I have a 04 2.5i sport package
      01-16-2013, 03:46 PM   #5
E85fan
      01-16-2013, 03:46 PM   #6
E85fan
      01-16-2013, 09:17 PM   #7
E85fan
Whoa phone glitched out lol triple post. Mods please delete
      01-17-2013, 08:24 AM   #8
SwissArmy
Why so serious?
SwissArmy's Avatar
A fellow zpost member looked it up for me. I will dig through my inbox and contact him on behalf of you.
Check your PM.
      01-17-2013, 12:45 PM   #9
E85fan
Check your PM.
Thanks
      01-17-2013, 12:45 PM   #10
E85fan
Check your PM.
Thanks
      01-17-2013, 12:45 PM   #11
E85fan
Check your PM.
Thanks
      01-17-2013, 01:07 PM   #12
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
It's not that hard to tell, if your headlights have a line light this, and turning on the brights just raises a shutter then you have Xenon lights
      01-19-2013, 06:13 PM   #13
snowmirage
Has anyone come across a close up picture of each headlight? After finally getting home and looking at them in person I'm 80% sure I don't have the HID option, but I'd like to be sure before spending the money.
      01-19-2013, 07:48 PM   #14
SwissArmy
Why so serious?
SwissArmy's Avatar
Can you open up the wheel well cover and check if there's an HID ballast there? I believe that would be a quick and easy way
