      09-15-2012, 09:58 PM   #23
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
be sure to check out *********** as well. they will have plenty of people better able to decipher your data
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
      09-15-2012, 09:58 PM   #24
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
doh! [Admin Notified] dot com
      09-15-2012, 09:59 PM   #25
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
oh snap, you're in trouble with DA LAW with links like that. hahaha
I'm gonna go to the drag strip again October 12th. Meth kit will be working by then
      09-16-2012, 09:42 PM   #26
Z4Murder
Z4Murder's Avatar
Drives: > speed limit
I would definetely go with some stickier radials... with some better tires you should be able to launch higher without much wheel spin, I don't think a 2k - 2.5k launch is unreasonable. You could also launch higher on your street tires with proper clutch slippage. It also comes with experience, my times went up alot from when i started drag racing in my last car.
2007 TiAg ///MCoupe
      09-16-2012, 09:47 PM   #27
ZStig
279
I'm not as concerned with a low ET as I am with a good speed at the end. If I was hitting 118mph all day, I'd know I'm making the proper power, and then I could work on the launch and worry about getting into the 11s.
If I can get consistent 2.0 launches on street tires, that should be good enough for decent runs. With lower tire pressures I might be able to go under 2.0 on my next time out.
I have no room to store a set of dedicated track wheels in my new place
      09-17-2012, 09:00 PM   #28
ZStig
279
Originally Posted by krnnerdboy View Post
I regularly dragged my z4m in the 1/8th and had 1 run down the 1/4mi.
my setup:
75 shot nitrous(basic setup)
muffler delete
AA tune
rpi scoop
bmc filter
my best 1/8th
60' 1.85, 1/8th 8.00 @ 91 mph in 1500da on worn out mt drag radials
best na 1/8th
60' 2.0, 8.5 @ 85 mph on dunlop direzzas 1200'da
street tired 1/8th
60' 2.2, 8.457 @ 90.08
my only 1/4 mile
missed 2nd gear 60' 2.4, 13.1 @ 117 2000'da
your 1/8th and 1/4 mile traps seem low for 500hp compared to my 75 shot, especially for your high 60' times. I'd assume traps in mid 90's in the 1/8th and 120 in the 1/4. Go on dragtimes.com and get your da for the day to see it more clearly.
your re-11 should be good for 2.0 60's....skip the water box, drop down to 20-23psi to avoid wheel hop, and do a quick burn on dry asphalt before you line it up(no brake application, 1st gear drop) oh yeah,open the hood in the pits, and avoid hot lapping
what do you mean by this? the elevation?
      11-10-2012, 07:53 PM   #29
ZStig
279
Well, I figured it out. A little bit of meth injection, 22psi in the rear, 66* ambient air temperature (vs 85 before), some more clutch slippage with a higher RPM launch, 500rpm shortshift on the 1-2 change, and a good combination of everything working together allowed me to launch like a beast in just 1.863 seconds for the first 60 feet
