      04-10-2015, 12:03 AM   #1
skidkid
Drives: 2007 Z4si
TPMS install
Do I need to remove the tires off the rims to replace the sensors and valve stem or can I get it done without removing the tire?
      04-10-2015, 03:39 AM   #2
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Tires off. Sensor is inside the wheel. Tires and wheels can be marked to avoid rebalancing.
      04-10-2015, 08:24 AM   #3
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
If you just break the bead where the sensor sits you can wiggle your way to have it put on. However I would recommend rebalancing once you put them on since the weight of the sensors themselves are going to throw the wheel balancing off.
      04-10-2015, 09:01 AM   #4
Incompatible
Drives: 07 AW Z4C 3.0Si
In most cases if you are replacing sensors, weight difference is insignificant and does not require rebalancing. If adding sensors then balancing is suggested.
      04-10-2015, 10:32 AM   #5
Daemonblitz
Commander
221
2008 BMW M5  [9.50]
I should have been more specific. If you are just swapping sensors no balancing required, but if you are adding them to wheels that just had conventional rubber valves I would re-balance.
