      04-03-2012, 01:49 PM   #23
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Originally Posted by pingpong View Post
OEM sizes: 225/40 fronts and 255/35 rears.
Those are OEM sizes so the diameters should be similar and won't be the cause of your issue. Tire Rack has tire specs listed on their website (including diameters).
      03-27-2015, 12:14 AM   #24
jaimebt
Mexico
Drives: 2004 e85 2.5
I recently replaced my rear tires with a pair of Goodyear F1 Asymmetric 2. The fronts are still the previous version Goodyear F1 Asymmetrics. On sweeping freeway onramp and offramps, DSC kicks in very very early, causing the car to understeer pretty dramatically.
Now before anyone says "the tires need to be broken in", there tires have well over 500 miles AND I can't even break them loose on hard corners stomping on the accelerator, so I'm very confident that they have plenty of grip.
From what I've read, it seems like the rear tires are probably bigger than the fronts, resulting in the car thinking the rotational speed between the front and rears are off, causing the DSC to kick in. Assuming that's the case, is there any way to reset the sensor associated with the DSC? My front's still have about 40% tread, so I don't really want to replace them.
did you solve the problem? im having the same issue...
      03-27-2015, 01:14 AM   #25
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Ancient thread with no updates. What's the story? What are your specifics.
