05-31-2011, 06:34 AM | #89 |
Turd in the Punch Bowl
19
Rep 239
I have been told by several people that a break in of the new head is not totally necesary.. That is more for the bottom part of the engine.. However, I have been a little easy on it so far.. It is running fantastic!!
03-05-2013, 07:07 AM | #93 |
Rep 4,057
Do you have any warranty left?
Get to a BMW dealer quickly and tell them to fix this and throw the bill in the paper shredder.
Huz-Z
03-05-2013, 04:02 PM | #94 |
Rep 155
03-05-2013, 06:11 PM | #95 |
Rep 4,057
I believe, but I am not sure, that some folks have gotten this done on out of warranty cars. So, the course of action is to request politely and firmly, and be persistent. This really should have been a general recall on the N52 engine in my view.
Having said that, does the car continue to make the noise when the engine has warmed up? I understand that while annoying, it's not harmful to the engine. But if it were me, I would want a BMW tech to make that determination for my specific car.
Huz-Z
03-05-2013, 06:21 PM | #96 |
Rep 4,057
The service bulletin appears at post 15 of this thread:
http://www.bmwcca.org/forum/index.ph...r-issues.5452/ So, clearly the BMW dealer maintaining this car knew about the potential for this issue and should have noticed and corrected it while the car was in for regular maintenance. You should go after this dealer first.
Huz-Z
03-05-2013, 10:59 PM | #97 |
Rep 1,530
Let's say the dealer fixed the lifters last year but then this spring, the car is still ticking. However, I am now out of warranty. The fact that BMW started warranty work on a known problem but weren't able to fix it in time qualifies the same issue be covered out of warranty?
I had my lifters replaced last year and it seemed to do the job. I've read in other threads that after a year of having the lifters changed, ticking would return.
03-05-2013, 11:16 PM | #98 |
Not a New Member
94
Rep 925
i've been dealing with this issue on various cars since 2007.
for all of those out of warranty with the n52... switch to 0w-40 full synth. it has drasticly reduced engine ticking (therefore increasing lubrication) in 3 of the 4 affected cars i've had this happen to. this weight is approved by BMW for this engine. the only reason BMW dealers use the castrol 5w30 synth is that BMW AG will cover only that during the maintenance period. i am not saying this fixes your car - it will allow you to buy some time to either save up the money to fix it, or *gasp* trade it in so the next guy gets stuck with it. all of us reading would prefer the first scenario. all mercedes dealers carry this on the shelf.
03-06-2013, 06:46 AM | #99 | |
Rep 4,057
The fact that the problem re-occurs indicates that BMW FAILED to meet its obligations under the warranty contract; as such they are not absolved from meeting those obligations when the problem re-occurs. So I would insist that they repair the car, even if the warranty has since expired.
Huz-Z
03-06-2013, 06:48 AM | #100 | |
Rep 4,057
BMW should have issued a general recall to address this. I know Honda would have in similar circumstances. Tell me again, why are we paying all this money for BMWs if issues like this are not dealt with in an ethical manner?
Huz-Z
03-06-2013, 07:46 AM | #101 |
Not a New Member
94
Rep 925
because your sig.
03-06-2013, 02:43 PM | #102 | |
Rep 155
03-06-2013, 02:44 PM | #103 | |
Rep 155
What specific oil do you recommend? Can I use mobil 1? |
03-06-2013, 02:51 PM | #104 |
Not a New Member
94
Rep 925
mobil1 is perfect. the link in my above post is to BMWNA, and specifically lists mobil1 0w-40 as approved.
03-06-2013, 03:22 PM | #105 |
Rep 4,057
The original warranty is transferrable between successive owners, so you should argue that the obligation to complete the warranty repair properly survives any change in ownership.
Huz-Z
03-08-2013, 11:58 PM | #106 |
Save the Manuals
1714
Rep 2,937
How has this turned out?
Take a look at LubroMoly 0W40 or Redline 0W40
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
03-09-2013, 07:41 AM | #107 |
Rep 4,057
I would INSIST that BMW complete the repair at no charge.
Huz-Z
03-15-2013, 12:09 PM | #108 | ||
Rep 1,530
03-18-2013, 02:01 PM | #109 |
Rep 155
ok, I put mobil 1 0w40 but not much change.
I've read tons about this issue and seems like BMW says it won't ruin the engine but people dont believe it. Me personally can't believe what BMW says too. If lack of oil at engine start up in the cylinder head does not cause problem, why do we need oil there at all? Maybe what BMW meant is that the damage is negligible???? I kinda like that ticking sound so if it does not damage or very little damage if it does, then I wont bother to fix it. Can anyone say if what BMW says is true? |
03-18-2013, 05:08 PM | #110 | |
Car Geek
3639
Rep 3,602
