      01-09-2018, 08:24 PM   #1
JCampbell_Soup
Australia
Drives: BMW Z4 E85 2.5i
O2 sensor simulator
Does anyone have a link for a place to buy oxygen sensor simulators? I have had down pipes for awhile now and the SES light is starting to bug me. Www.o2sims.com or whatever it was seems to have vanished from the internet and they are the only ones people seem to have mentioned.
      01-09-2018, 10:04 PM   #2
2289
Google area seventy 4, that's what I used and they worked flawlessly.
3GFX722.50
      03-07-2018, 09:12 AM   #3
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Question, is this puppy still working?
Getting to be that time for me.
I need something that will pass with no cats
      03-07-2018, 09:17 AM   #4
Drives: M2 Comp
This.
      03-07-2018, 09:35 AM   #5
3GFX
3GFX's Avatar
This.
Beautiful. Just to clarify....with no cats...I would need 2 of these sims one for each pipe correct?
I've reached out to the tuner to see what can be done as well. Wanna double check to see exactly how they programmed the car. If the second cat is "turned off" I will have no choice but to go get it tuned anyway before it will even read the simulator.
      03-07-2018, 11:15 AM   #6
3GFX
3GFX's Avatar
Also... M54 vs N55....will the sim work the same?
      03-07-2018, 11:34 AM   #7
Steeler
Steeler's Avatar
2430
Send Area 74 a note on their website
      03-07-2018, 01:00 PM   #8
2289
Yes one for each sensor therefore you will need 2. After numerous unsuccessful attempts by my tuner, I ended up using these simulators and they worked great. Occasionally it trips a CEL when I’m driving WOT for extended periods [on track] but simple reset with my phone does the job. For everyday driving and street it’s never tripped a CEL. This simulator should work on all engine platforms, m54, n52, n54/55, and s54.
      03-07-2018, 01:03 PM   #9
2289
Yes but for N55 you’ll only need 1. And install should be little easier because N55 is more accessible. If your m54 is anything like mine where the post cat o2 sensor connects underneath the car, you will most likely install on the DME side inside the ECU enclosure. And honestly I prefer that anyway because the sensor is protected from the heat and weather (and remains hidden). Removing the ecu took more time than installing the sensor.
Pictures are down but my brief write up:
http://www.zpost.com/forums/showthread.php?t=1394920
3GFX722.50
      03-12-2018, 05:53 PM   #10
JCampbell_Soup
Australia
Hi all, i ended up buying two simulators from magnum tuning and they work great. They were still pretty expensive but they worked. They were simple to install. I bought the ones that dont have the heater circuit in them as they were way too expensive but i wish that i bit the bullet and bought them for completeness of the mod. I am going to make a small metal box and house the heaters to avoid excessive heat under the hood or perhaps find a suitable resistor (something heavy duty like ceramic) to bypass the heaters.
No codes so they 100% work
2003 BMW Z4 e85
Bilstein B12 Struts and Springs|S52 Downpipe w/ Custom Adapter Plate|Style M208 Wheels|Oil Catch Can|Strut Tower Brace|Intake Scoop|CAI|AUX and Bluetooth Fitted
1987 BMW 535i e28
Stock Restoration Project
3GFX722.50
Tags
bmw z4, catless downpipe, oxygen sensor, simulator
