10-30-2013, 06:40 PM | #177 |
Rep 347
Drives: 2006 BMW M COUPE
You embarrassed some of the Porsches especially the Cayman with the wing - good on ya ! The GREEN M-3 must be a write off - scary considering what he probably paid for it in race trim - looked like a lot of fun - hard to tell top speed on the straights = ??
2006 M COUPE - 380 total production, 1 of 40Imola Red produced for NA , ESS 455 Supercharger, Speedhut Gauges, VPM CLS wheels, 19" Hancooks, Stromung Exhaust, Carbon fibre accessories and black and white badging,
10-30-2013, 06:59 PM | #178 | |
11039
Rep 4,920
Those are mechanical systems on a z4m. As long as your multibelt doesn't snap you have power steering afaik, and as long as your engine is running (at any speed), you have vacuum to use the brake booster. The remaining vacuum (in case your engine stops alltogheter) is held up by a one way valve, so there's always vacuum for 1 stop. Loosing brakes all together is only possible if you have a leak in the lines or the mastercilinder breaks or something like that. Just my 2ct.
10-30-2013, 07:15 PM | #179 | |
Rep 892
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i |
10-30-2013, 07:36 PM | #180 | |
Rep 2,176
10-30-2013, 07:38 PM | #181 | ||
Rep 2,176
George |
10-31-2013, 04:25 AM | #182 | |
11039
Rep 4,920
Otherwise there is no 'limp' But still with shutdown: as long as you do not press the clutch you engine keeps spinning That you loose traction is of course confusing (so in theory dangerous if you're not experieced or unable prepared), and it upsets the balance, but as long as you dont start to brake excessively, or regain drive(which you wont) you should be fine. Just a matter of keeping your head cool. I've dealt with this situation too (the m54 ts2 kit also can have the exact same quirks in certain situations as i found out.....) But my point was that the describes flow of events was not possible imho (if i'm wrong: please explain), not that it would be potentionally dangerous or annoying. Describing the exact event is important to investigate possible solutions to the problem (that's the whole point isnt it?). Also limp mode should generate a specific bmw eobd code which you can read with inpa. It might be sensible to do that if possible.
10-31-2013, 04:42 AM | #183 | |
Rep 879
And trust me, if that limp mode happen during a hot lap on the track with a driver that is able to push the car to the limit of the grip, it is dangerous! |
10-31-2013, 05:43 AM | #184 | ||
Rep 2,176
It happened to me at 100 mph in an off camber sweeper , in which I was using the throttle to balance the car . The rpm drops to 800 with massive engine braking and 0 throttle response . It's game over no matter how good a driver you are in that situation ,guidok don't tell me it's not possible . I have the 10 k repair bill to prove it . George |
10-31-2013, 09:33 AM | #185 | |
11039
Rep 4,920
Because THATS what were talking about here. A bill doesnt 'give' a technical explanation, so i'm not sure what your trying to say with that statement other than crashing a car.
10-31-2013, 11:19 AM | #187 |
Rep 5,329
10-31-2013, 11:37 AM | #189 | ||
11039
Rep 4,920
That he can loose power in limp mode..... well... yeah..... that's what limp mode is all about isn't it? (I haven't said otherwise I think?) And that you can crash your car at the track......that happens too (all the time....). Be happy that you can live to tell I guess... But it boggles my mind that no one else catched that limp mode couldn't result in loss of power steering or brake failure, and that something else must happen to be the cause of that (Not that that isn't possible: 2 unrelated problems at the same time!). And it's strange that no one (apart from this minimal post) have read their car with INPA and posted some printscreens after such a major failure as more VT-XXX owners apparently have had the same problem (at least: you won't know that until you analize your DME if you catch my drift ). I mean: that's where problem soving starts.....(first thing I do is hook up the laptop....) That the car goes into limp mode is not the problem, but the result of the problem. The problem lies in the DME deciding to go into limp mode, because he sees some parameters. Those parameters can mean the problem (that's probably hardware), or the interpretation of the DME can mean the problem (tuning).
10-31-2013, 02:14 PM | #190 | |||
Rep 2,176
Not sure who pissed in your cornflakes . I'm just trying to help out the Z4M community with my trouble shooting and extensive track experience . |
10-31-2013, 04:19 PM | #191 |
instagram 997turbotom
286
Rep 7,377
Can't an Iphone program called Rev, along with a OBD2 blutooth transmitter do datalogging? Or something similar. Would be nice to run this on the track
10-31-2013, 04:33 PM | #192 | |
Rep 2,176
11-12-2013, 09:47 AM | #193 |
Rep 2,176
Just had a great weekend back at Roebling with the Darkside PCA. I hit a new personal best lap of 1:20.5 , consistently beat a modded 997 GT3 RS on Hoosier R6's and hit 150mph by Aim solo GPS on the front straight also my personal best by 2mph. I just installed my DKF catless S pipe and it def made a difference up top. Per usual i had two episodes of the limp mode over the 8 sessions but I'm a pro at a quick restart while rolling now Hopefully ESS will have a fix for use soon other wise the car is running perfect now. I'll post some videos in the track section later. FYI the Hankook Ventus TD C30 (hard compound) is a great performance option for those who drive to the track like me , they are doing fantastic wear wise as well. Its looking like the fronts will last 6 days and the rears about the same. This will make it the fastest and most durable tire I have used thus far including extreme performance street tires as well as DOT R's. NT0-1 , Michelin sport cups, Re-11's,Michelin PSS, BFG rivals.
George |
11-12-2013, 11:06 AM | #194 | |
286
Rep 7,377
11-12-2013, 11:57 AM | #195 |
Rep 2,176
Oh it's def worth it ! Our cars are great platforms , I was even beating his apex speeds . Given his modded GT3RS mark 2 has at least 475 hp , better gearing ,weighs 200 pounds less than me, and can get in the gas much earlier coming out of turns( aero , rear engine and 335 R6's ) it's a testament to the performance of the kit that I was hitting 2mph faster speeds than him at the end of the straight despite starting in 5th gear to avoid limp mode . The GT3 RS driver is a friend and I was able to look at his Aim solo data so no conjecture . As expected he would pull early , then I would close rapidly at the end of the straight .
11-12-2013, 01:44 PM | #197 |
Rep 5,329
incredible that a tuned z4m can run with the big boi's like this.... even with the limp mode its kicking ass, cant wait to see what you can do without the limp problem!!
11-13-2013, 06:47 AM | #198 |
Rep 2,176
Here is my fastest session of the day with a 1:20.5 lap. Me and a 2400 pound E30 were tearing through the field . I slowed down to let him by at the end so i could get him on film. He was a great driver , and a little crazy lol.
