03-25-2014, 06:08 PM | #1 |
Rep 3,939
Aero side skirts
Are they a direct fit for the M Coupe? Were they a factory option? Where can I find them and how much do they run?
Thanks! |
03-25-2014, 06:20 PM | #2 |
Rep 1,443
1. Very close. Search. Easy modification if even necessary (seems like some have been fine without cutting the notch.
Edit: I think this thread addresses the possible need for trimming: http://www.zpost.com/forums/showthre...ht=side+skirts (Yep. Page 2.) 2. Probably? 3. Anywhere that sells BMW OEM parts as long as they haven't run out. A year or two ago I know I hear they were in short supply.
03-25-2014, 06:54 PM | #3 |
Rep 2,542
Simple install, takes an hour or less to remove the old ones and put the new ones on. Cost around $500 for the pair, come unpainted, so factor the paint work with a flex agent into the cost. The M should have come with them stock, but didn't
03-26-2014, 07:13 AM | #5 |
Rep 1,134
Drives: '07 M Roadster
getbmwparts.com has them for 245 each side in the accessories tab, but if you search the part numbers under PARTS they're 179.16 each, not sure why. They were not offered on the M models, but the parts do still fit. Because they werent offered to find the part numbers you have to search realOEM or other sites for the other Z4 models.
http://www.getbmwparts.com/parts/ind...&siteid=214672 and http://www.getbmwparts.com/parts/ind...&siteid=214672
03-26-2014, 07:36 AM | #6 | |
Rep 3,939
Thanks for the info!! |
03-26-2014, 12:10 PM | #8 |
Rep 1,134
I had to double check my order from last year. I'm pretty sure they were sold like this last year too with the different prices and like an idiot I bought the more expensive ones
Also paint might be different where you are, but for me it was around $460 to have them painted and installed.
03-26-2014, 02:07 PM | #9 | |
Rep 1,443
03-26-2014, 09:54 PM | #10 |
Rep 452
Before you install them, do a search on this forum. I recall making a very slight mod to mine because the car is an M. Not sure why this is, but it made a small difference.
