03-18-2010, 09:45 AM | #1 |
Save the Manuals
1714
Rep 2,937
z4 M owners: must read
>> for z4 M owners <<
my production date was 6-1-06. with 735 miles on it, the passenger side motor mount bolts (per the service bulletin) were found to be loose, not broken thank goodness. All four bolts were replaced under warranty. I have a Roadster... I would advise every z4M roadster or coupe owner to have the dealer check it out. you don't want to find out the hard way... I am re-posting this throughout the various forums/ sorry if it seems redundant; it's too important not to broadcast... (thanks to all the early contributors that have brought this to light!) http://www.unofficialbmw.com/images/...torbracket.jpg
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
03-18-2010, 10:25 AM | #2 |
Rep 1,721
Pretty sure this only affected the 06 models.
BMW CCA Track Instructor
Join to win a M School Day at the Performance Center! Enter Referral ID: 420186 |
03-18-2010, 11:29 AM | #3 |
Rep 421
I'm only a couple hundred miles from my next service and have been meaning to have this checked. Thanks for the reminder. I'm sure having the service bulletin number will be helpful to convince the dealer of the necessity. Did you have this done at D&R North?
03-20-2010, 07:22 PM | #5 |
Rep 349
03-21-2010, 04:43 AM | #6 |
Save the Manuals
1714
Rep 2,937
Read the bulletin.... ALL production....
2023 G80 6MT, CCBs
03-21-2010, 06:04 AM | #7 |
My favorite sign.
169
Rep 4,333
Mine is an 07 and the bolts were all jacked up.
03-21-2010, 08:24 AM | #8 |
M Slut
18
Rep 564
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
Really? How did that happen?
You have to be 100% behind someone before you can stab them in the back.
David Brent |
03-21-2010, 10:00 AM | #9 |
Imola Lover
26
Rep 749
This is pretty common knowledge on all the forums, actually (there's a post in the FAQ here about it). Although it typically has only happened to 07-year coupes. The problem is that shops don't check even if you ask them to, whether there's a bulletin or not.
03-21-2010, 11:58 AM | #10 |
Rep 4,320
Drives: '07 Z4 M Coupe
It's still worth mentioning even if you have an 07-08. I brought in the SIB and had them take a look, two of the four bolts were found to be loose.
03-21-2010, 01:20 PM | #11 |
Save the Manuals
1714
Rep 2,937
how many miles were on her when you discovered the broken(?) bolts?
2023 G80 6MT, CCBs
03-21-2010, 02:31 PM | #12 |
Imola Lover
26
Rep 749
Forgot which forum I was on. It's in the FAQ over on bimmerfest. The vast majority of affected vehicles on the forums have been 07 coupes.
03-21-2010, 02:44 PM | #13 |
Skull Squadron Leader
306
Rep 2,031
I brought in the SIB and my dealership swapped the bolts out with the one in the bulletin. This was over a year ago.
There's no reason why it shouldn't be checked if you have the SIB in hand. |
03-21-2010, 03:57 PM | #14 | |
My favorite sign.
169
Rep 4,333
Not sure, the car had about 20k on it when I got here and about 26k now...somewhere in the middle...
03-22-2010, 08:46 AM | #16 |
Rep 349
I bring it to the dealer for oil change, and they
said they gonna tune my engine to keep its performance. And then, second day after i got my car back. I was on Fwy going 80miles, the engine stalled .... car died on Fwy ... toll it back to dealer ... they tried to balme on me <Aggressive Driving> ~ isn't that obvious M is made for "Aggressive Driving" ??? anyway, I forced them get me a new engine for free. After replaced engine, car start having problems ...[BMW HQ told me four bolts from intake where sucked into the engine]. |
03-22-2010, 10:34 AM | #17 |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
Took mine in for a tire vibration last Thursday. Asked the SA to check out the bolts since there was a SIB out on it. Went in to pickup Thursrday evening. He flat out told me there was no such service issue or SIB issued for that problem. Said not to worry about it. How about those beans. Joe Machens BMW, Columbia MO
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings Last edited by mousitch; 03-22-2010 at 10:58 AM.. |
03-22-2010, 10:43 AM | #18 | |
Imola Lover
26
Rep 749
03-22-2010, 10:52 AM | #19 |
Rep 11,667
I've been following this issue from when I had my M roady.
Now that I have the M Coupe on the way, I'm going to get this done whether they are loose now or not. Just curious, has anyone heard of this issue with the S54 in the M3, or is this just Z4 specific? |
03-28-2010, 06:27 AM | #21 | |
BMW Fan
11
Rep 553
BMWNA isn't going to do anything about a problem like this involving a few thousand cars made several years ago. If you want to make sure you will not have broken engine mount bolts, the only true fix is to replace all 8 bolts with grade 10.9 bolts, make sure they are properly torqued to spec, and use some kind of thread locker to prevent them from loosening. |
03-28-2010, 06:40 AM | #22 | |
BMW Fan
11
Rep 553
On the rare occasions that I do take my car to the dealer, I do several things to try to avoid problems: I tell them to not wash or clean the car at all I try not to leave the car overnight I make the SA fill out a sheet showing that there are no nicks, dings, or scratches anywhere on the car I have one tech who has been there for over 10 years who works on my car. |
