      03-31-2012, 08:15 PM   #1
Toneloc111
Drives: 2003 Z4 2.5i
2003 z4 question
I actually used my air conditioner today. It really blows cold for a German car! But, at the light, I went to accelerate and the car almost stalled! And a couple of times it did the same. But not all the time. Has this happened to anyone? And if so, what's going on? By the way it's a 2.5 with automatic trans.
Thanks!
      04-01-2012, 06:49 AM   #2
DataStream18
Drives: 2003 ESS TS1 Z4
Sounds like the AC compressor clutch is causing to much drag on the engine. Take it to an AC mech and have them look. Small chance you need a new one as it is 9 years old.
TS2/Cat-Less Headers/Jet Hot Coating 2000/CF Engine covers & Oil Cap/RPi Scoop/Matte Black Grills/H&R Sport Springs/15mm Spacers Rear/12mm Spacers Front/Flowmaster 40 series/Alcantara Shift Boot/CF Vinyl wrap/SPEC Stage 2+ clutch/8 Lbs Fly wheel/ZHP Shift knob/Hawk HPS Pads/Cross Drilled/Slotted Rotors/Performance Pedal Set/Stewart water pump
Love is like a fart; if you have to force it, it's probably shit.
