      08-26-2013, 04:08 PM   #1
braindamage
Drives: E92 M3
18x9 setup on all 4 with TR Motorsport MT-1?
Anyone running 18x9 35mm TR Motorsport MT-1 on all 4 corners? If yes, what kind of tire size are you running? Wondering will this setup with 255/40/18 works.
Thanks.
      09-01-2013, 09:32 AM   #2
2280
I'm running the mt1-r, slightly different design. 17" with slight lip so the spokes look little smaller but the size was perfect for a cheap track wheel (17x9 et 40 square with 5mm spacer on all 4 effectively making it 35mm offset) with 255/40-17 but for a M you may as well go 265/35-18. Are you on stock suspension though? You may run up front without some camber.
      09-07-2013, 08:38 PM   #3
braindamage
Drives: E92 M3
Suspension is currently stock but will have coil-overs in the spring time. Reason for 255/40-18 is because that is the "correct" tire size for 9" rim, which is also the stock rear combo.
For the MT-1R, they have 18" diameter now but only available in 18x9.5 for now.
