02-24-2012, 04:54 PM | #1 |
Rep 2,737
antenna and rear key hole delete....
hey guys I’m thinking about deleting my antenna and running it on the inside of the rear quarter and having the hole plugged up and painted over. what do you guys think.
I listen to nothing but satellite radio, hate commercials and the radio does not play the music I listen to anyhow..... so the antenna is not important to me. I’ll still have it but it will run inside the body panel versus sticking out... how do you guys think it will look..... will it make it to plain? also planning to have the locking mechanism from the new Z4 retrofitted to my trunk deck lid so I have the BMW badge that also acts as a handle. this will be like you coupe owners always had been jelouse lol..... this will delete the lock cylinder in the rear and plan to either use the hole as a spot to use as a rear camera or plug it up entirely and smooth it over and paint it... also cleaning up the rear. what are your thoughts? sort of like this!!!! or this... Last edited by -c-; 02-24-2012 at 05:18 PM.. |
02-24-2012, 05:42 PM | #3 |
Rep 556
Drives: 2003 ESS TS1 Z4
I like the top best but what happens when you need to unlock your trunk and you cant? Just a thought.
TS2/Cat-Less Headers/Jet Hot Coating 2000/CF Engine covers & Oil Cap/RPi Scoop/Matte Black Grills/H&R Sport Springs/15mm Spacers Rear/12mm Spacers Front/Flowmaster 40 series/Alcantara Shift Boot/CF Vinyl wrap/SPEC Stage 2+ clutch/8 Lbs Fly wheel/ZHP Shift knob/Hawk HPS Pads/Cross Drilled/Slotted Rotors/Performance Pedal Set/Stewart water pump
Love is like a fart; if you have to force it, it's probably shit. |
02-24-2012, 05:53 PM | #4 | |
Rep 2,737
02-24-2012, 06:32 PM | #6 |
Rep 2,877
The antenna won't work inside the body (the metal cage - essentially a large GND cage will prevent reception). If you plug up the hole, what will be your plan if you ever sell it?
02-24-2012, 06:38 PM | #8 | |
Rep 2,737
02-25-2012, 06:16 PM | #10 |
Rep 2,138
Drives: Me
AM radio should not work. FM uses both the rod antenna and the FM only antenna along the rear bumper.
The other minor issue, where are you are going to mount the AM/FM amplifier that is used to bolt the rod antenna to the fender? |
02-25-2012, 11:02 PM | #11 | |
Rep 2,737
02-26-2012, 07:54 AM | #12 |
Rep 11,669
I'd love to delete the antenna as well.
Although not ideal, I might try some sort of flush hole cover rather than filling & repainting. (reversible as well)
02-29-2012, 09:56 AM | #13 |
Rep 217
Top photo looks ultra clean, I absolutely hate the rear key hole on the rear deck lid. I was actually going to look into seeing if the OEM painted door handle plugs off a 5 series fits into the Z4 deck lid key hole. Your option is obviously better and cleaner but a smooth painted plug I can pop in in 2 seconds is lso a nice option.
Does anyone knw if the E60 5 series key hole plug will fit? |
02-29-2012, 11:26 AM | #14 |
E93 Pilot
Rep 6
I like the clean look too; you have my vote. My iPad contains my music so I never turn on the radio. The keyhole is always grimmy anyway and is a magnet for drafted dust onto the key-lube area. I'd agree with datastream18 as just in case you need access. i'd try and find an alternative release (move the "T" handle or add another one in the aft console?) location for emergency or battery failure or your battery cable jiggles lose.
02-29-2012, 12:19 PM | #15 |
instagram 997turbotom
284
Rep 7,377
If you're gonna re-paint the trunk, I say you might as well shave off the BMW badge too. If you're going for the clean look, go all out
02-29-2012, 06:03 PM | #16 |
Rep 2,737
Hey guys!
well the new latch from the 09 and up Z4 has the lock key hole in the badge much like the coupes have. you can push the badge back and insert the key if needed. and i can also reroute cable to make a emergency release behind the driver seat under the carpet incase of dead battery or anything of that matter. otherwise its all good....... its ok to be clean but not to baron or sparce a little detail is always good.... so the badge can stay........ otehr than that that will have to wait....... picking up my new hardtop here in a week or so!!!! yayyyyyyyy! |
02-29-2012, 06:10 PM | #17 |
40
Rep 1,481
On a convertible...couldn't an antenna be hidden inside the canvas top somehow ? Making sure that it goes with the flow of folding, of course.
03-01-2012, 12:14 PM | #18 |
Rep 1,224
Would it be possible to mount a short AM antenna on the backside of a roll hoop? Maybe in a black plastic cover to blend with the oe cover? BTW, really like the cleaner lines of the lock/antenna delete.
05-19-2014, 05:48 PM | #19 |
Ammar
73
Rep 406
Bringing back a dead thread.... But has anyone successfully done this?
I'm actually really interested in doing a retrofit like the coupes have and moving the keyhole to where the badge is. Also, couldn't you hide the antenna and stuff inside the plastic roll bar covers? Reception should still be able to get through plastic and I'm pretty sure there's lots of room in those housings.
2018 F150 Platinum - Black/Black - Leveled on 34's - DD |
