08-14-2011, 04:07 PM | #1 |
Rep 91
Drives: 2007 Z4MC
3d Design Gauge Pod -Stack Gauges
Here some photos of my Gauge Pod installation -Coolant temp;Oil Pressure ;& Boost Gauge- Along with the under hood installation and finsihed look - Gauge pod looks as if it "belongs" but console has to be removed and the pod is installed from the bottom.
I'll try and answer any questions |
08-14-2011, 04:12 PM | #2 |
11818
Rep 23,187
looks good. how long did the install take.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
08-14-2011, 04:19 PM | #3 |
Rep 91
Drives: 2007 Z4MC
install time
If i did another install I would say 4 hours in total. It took me about 8 hours in total working on them as time permitted and not having done this before.
Now "discovery work" would be much less!! Example- can use the gear shift light wire for the dimming feature. Any other questions let me know |
08-14-2011, 08:34 PM | #4 |
Rep 1,224
Looks good. Who's gauges?
08-15-2011, 03:34 AM | #6 |
Rep 91
Drives: 2007 Z4MC
supercharger
VT1 has been great!! Driveability is as before install but with much more power . Only hikcup was a breaking down at 6000 rmp and new spark plugs took care of that . Acceleration on the track is awsome (our track is 2.5 kms with 11 turns so quick acceleration really helps-Google "Atlantic Motorsport Park"). I have followed the VT 2 kit installs with interest and hope that over the winter the bugs that seem to be fixed by "trial & error" will be corrected and it will be as the VT1 kit-then I'll consider it .
08-15-2011, 03:35 AM | #7 |
Rep 91
Drives: 2007 Z4MC
Gauges
08-15-2011, 01:12 PM | #8 |
Rep 5,329
nicceee install ;-)
honestly??? can you get a better gauge than the stack pro units!! freakin awesome gauges that can even data log when hooked up to a certain unit...
08-16-2011, 09:21 AM | #9 |
Rep 452
Noticed that you have the temp sensor in a spacer in the upper rad hose. Was there any reason why you did not use the block drain for the sensor? I'm asking because I'm making the same install and I was expecting to use the block drain for the sensor. Btw, really like the gauges. I'm using AutoMeter myself.
08-16-2011, 09:54 AM | #10 |
Rep 11,669
Nice job Wayne.
I still love to have a full set of gauges someday. FWIW This thread shows another location for an oil sender, instead of the cap mount. http://www.bimmerfest.com/forums/sho...29&postcount=5
08-16-2011, 04:34 PM | #11 | |
Rep 5,329
08-17-2011, 05:31 PM | #12 | |
Rep 91
Drives: 2007 Z4MC
gauge install adaptors
08-18-2011, 08:27 AM | #13 |
Rep 452
Thanks for the tip. Can you please post the contact information for this coolant hose adaptor?
08-18-2011, 08:54 AM | #14 | |
Rep 11,669
There are snippets all over the place. When it comes to senders there are several pick up point options & methods to wire them back. It be nice to compare.
07-03-2012, 07:43 PM | #15 | |
Rep 11,669
do you have any info on the thread size for that port? what adapter did you use?
07-04-2012, 04:20 AM | #16 | |
Rep 5,329
hmm bear with me, i'll dig the info out but its the perfect location for the oil pressure and even better i ran al the wiring WITHIN the stock sheathing... you simply cant tell theirs aftermarket wiring under my hood.... The main reason i wanted it in the spare port next to the oem low pressure sensor was mainly for accuracy, oem like install and i wanted to keep the oil filter house as just that.... an oil filter housing.... for me i simply didnt want to have to disturb wiring for my gauges at every service... ill grab you this info today but i can tell you i managed to find a local motor place that have the correct adapter that fits perfectly and was under 20 bucks......
07-04-2012, 04:59 AM | #17 | |
Rep 11,669
Your reasoning is exactly the same as mine. I want this as OE looking as possible. I want to do the same for the water temp using the block drain down location. I'm pretty sure the water is an M14 - 1.5 If you happen to have any pics of what you did for both locations, that would be fantastic.
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 07-04-2012 at 07:33 AM.. |
07-04-2012, 08:39 AM | #18 | |
Rep 5,329
i dont have water temp as the car shows an amber warning when it gets to warm, and a red before overheating.... not ideal but i didnt want to waste my gauge space for water temp, my car has never shown even an amber light even in the 30 deg C all day track days.... i have stack boost pressure in psi,stack wideband and oil pressure in psi, also show in the video.... again all gauges have been routed within stock wiring sheathing and is completely undetectable....
07-04-2012, 03:50 PM | #19 | |
Rep 11,669
That's exactly what I was thinking Do you happen to remember the size of adapter you bought for that spare port? I have access to local sources but so far can find the size spec on realOEM parts or in the TIS.
07-04-2012, 04:17 PM | #20 | ||
Rep 5,329
Ill get you a link from the exact place I got it from, You can see the part in my clip, it was a risk but the part fitted like it was a BMW piece. Will report back.
07-04-2012, 06:00 PM | #21 |
Rep 11,669
That would be great ....thanks!
07-05-2012, 05:40 AM | #22 |
Rep 5,329
here we go....
m12 1.5. http://www.demon-tweeks.co.uk/motors...essure-t-piece if you struggle to find a cost effective piece paypal me the change and ill order this and send it over to you. :-) shipping this via the post office will cost a few £, nothing major at all.
