07-27-2015, 07:44 PM | #1 |
Rep 268
Z4M ECU hard to work with?
I've been having troubles trying to communicate with my ECU despite my best efforts and many attempts. Here are my symptons:
1. I have a k+dcan cable and an NCSExpert setup (which has all been tested and verified by people much more in-the-know than me) which is also not able to read the ECU properly. It's giving data-transmission errors and faulty VIN errors, etc. 2. I have the enthusiast Bavarian Technic kit. Does not automatically identify car, and also is not giving me any proper data when I try to data log. If I had just one or the other happening to me I wouldn't be so nervous, but combined I'm wondering if there's is something locked down, or wrong with my ECU? I've also contact VF who supplied my supercharger tune, and they confirmed that their tune doesn't lock down any communication with the ECU. So --- has anyone else had a similar experience, or can you suggest anything I should look for, test for? Thanks. |
07-28-2015, 01:12 AM | #2 | |
Rep 162
Drives: 2008 Z4 3.0si Coupe
The software can be quite stubborn to get working. I hope you find this helpful.
2008 Z4 3.0si Coupe
07-28-2015, 08:30 AM | #3 |
Rep 268
I've tried the car on ACC and with the engine running. The person I bought the cable from tested it before shipping and said that it should have a switch built into the cable to auto-connect pins 7 & 8, however today I am going to bridge them manually anyway to see if that could be the problem.
I do have the COM port setup correctly and the right NCS profile I'll report back after my pin test. |
07-28-2015, 08:57 AM | #4 | |
Rep 162
Also, I connect the cable as soon as I need to do anything. It tends to time-out if I leave it connected to USB with no activity. Have you also checked the fuse for the OBD port? Before bridging pins 7 & 8 manually, test the pins to ensure the switch works. And if you get it working, don't forget to try NCS Dummy.
2008 Z4 3.0si Coupe
07-28-2015, 05:50 PM | #5 |
636
Rep 3,124
When you run INPA, it spawns EDIBAS, which I think is a lower layer protocol required for the cable to work.
When you close INPA, EDIBAS stays running. You'll see it in the task bar.
07-29-2015, 08:37 AM | #7 |
Rep 162
Are you running your software on a VM?
2008 Z4 3.0si Coupe
07-29-2015, 08:54 AM | #8 |
Rep 268
No, it is a Dell laptop with Windows 7 on it. I setup a VM on my Macbook last night and can't get it to install drivers at all for the cable -- doesn't recognize it. So I might be doing something wrong there.
07-29-2015, 09:17 AM | #9 |
Rep 1,443
Regarding the BavTechnic Enthusiast Kit not automatically identifying the car, it doesn't unfortunately. I got the Enthusiast Kit for Christmas last year and really have had nothing but trouble with it. It has come in handy for a couple off the wall things but I have yet to be able to reset a service interval.
