      12-08-2010, 11:46 PM   #23
BlackMoupe
Mouper
BlackMoupe's Avatar
Drives: _____
Thanks for the info! Looks like I'm gonna pull the trigger!
      12-09-2010, 01:56 PM   #24
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
Talking
Originally Posted by F360C View Post
Sorry for the delay.... tire sizes are stock e9x M3 sizes. 245/40/19 front and 265/35/19 rear
e9x M3 is actually 245/35/19 stock for the front. So does this mean that to run those rims without rubbing on stock suspension setup i have to run skinnier tires ? or with a decent amount of negative camber, maybe with the pins pulled i can get it to fit without rubbing on the fender liner?
Also, your blacked out headlights look sweet, do they just have a film of tint on them ?
      12-09-2010, 09:56 PM   #25
F360C
Drives: E86 S54
Hey good spot I don't know why I thought that they were 245/40/19. You are indeed correct that they are 245/35/19. I am pretty sure you can get away with -1.5 (how much you can get with the pins pulled) and I am totally sure you can get away with -1.9 (how much you can get with a slight drop).
Head lights are the lamin-x smoke film. it is so weird how it look a different darkness in every picture.
I notice you are from Barrie.... I lived there for the past 4 years.
07 Z4 M Coupe AW/IR
      12-10-2010, 10:43 AM   #26
Daemonblitz
Commander
221
2008 BMW M5  [9.50]
The film looks great, looking at that last pictures i thought u actually had the backs of the headlights painted from silver to black.
And yes i am from Barrie, i have heard some things about you and your brother. Oh, and i am taking the Auto Management program at Georgian there as well, you took the same program did you not ?
      12-10-2010, 11:01 AM   #27
F360C
Drives: E86 S54
Yep I took the Auto Management Program at Georgian! A chick friend of mine that goes there said she spotted a IR MC on campus and I was thinking that since your MC is IR and you are in Barrie that it must be you. Do you track the car at all?
07 Z4 M Coupe AW/IR
      12-10-2010, 12:39 PM   #28
Daemonblitz
Commander
221
2008 BMW M5  [9.50]
Yup, that was me on campus, in 47000 miles the car has never seen track though... YET, but i am really wanting to take it out... when i finish this final year of school and have more time on my hands I'll definitely give it a go.
      12-10-2010, 01:48 PM   #29
bmwtmx
bmwtmx's Avatar
112
Drives: 2008 BMW M3
I am glad we found out the 19's work. How about the 18's?! I've looked and looked but nothing yet. And does anyone have weights for these wheels?
      12-10-2010, 02:31 PM   #30
Daemonblitz
Commander
221
2008 BMW M5  [9.50]
If the 19s work i don't see any reason why the 18s would not. They are still the same width and offset.
F: 8.5" wide ET:29
R: 9.5" wide ET:23
As for weight BMWs "claimed" numbers, the 18s are:
F: 11.05 kg (24.36 lbs)
R: 11.75 kg (25.90 lbs)
The 19s claimed weight:
F: 10.7 kg (23.59 lbs)
R: 11.4 kg (25.13 lbs)
As a point of reference our stock rims claimed weight for cars built until 12/07:
F: 12.15 kg (26.79 lbs)
R: 13.65 kg (30.09 lbs)
Cars built after 12/07:
F: 12.0 kg (26.46 lbs)
R: 13.3 kg (29.32 lbs)
Again, these are the "official" numbers according to BMW, and real life weight might be slightly different, but it still gives you a good reference.
Last edited by Daemonblitz; 12-16-2010 at 01:25 PM.. Reason: Added weights in imperial
      12-11-2010, 08:36 AM   #31
lucid
lucid's Avatar
Drives: E30 M3; Expedition
Yes, 18" and 19" have the same offset and width. 19" is forged whereas 18" is cast.
      12-11-2010, 05:59 PM   #32
F360C
Drives: E86 S54
Dude you have got to get that car on the track! It is like having a GF and not sleeping with her. Yeah they are nice to look at and fool around with but the real fun is in the sack. I have tracked this car since the day I got it and I now pity that I did not track my last BMW. I wasted all that time I could have been on track getting better. I am sure you can find a wednesday night to head down to Cayuga and drop $60 on some lapping.
07 Z4 M Coupe AW/IR
      12-15-2010, 10:00 PM   #33
Daemonblitz
Commander
221
2008 BMW M5  [9.50]
Originally Posted by EndlessZ4M View Post
I am picking up the OEM E92 M3 19 inch wheels for my Z4M.
Have you picked them up yet ? i am waiting to see how they fit and what your verdict is on these, get some pics up !
      12-16-2010, 01:12 PM   #34
bmwtmx
bmwtmx's Avatar
112
Drives: 2008 BMW M3
[QUOTE=Daemonblitz;8478304]If the 19s work i don't see any reason why the 18s would not. They are still the same width and offset.
F: 8.5" wide ET:29
R: 9.5" wide ET:23
F: 11.05
R: 11.75
F: 10.7
R: 11.4
F: 12.15
R: 13.65
F: 12.0
R: 13.3
Again, these are the "official" numbers according to BMW, and real life weight might be slightly different, but it still gives you a good reference.[/QUOTET
These weights are of course not correct unless you are using a different scale. Stock wheels are mid 20lb range. 18's are better for the track in my opinion. More tire options, less weight, lower cost, faster car.
      12-16-2010, 01:20 PM   #35
Daemonblitz
Commander
221
2008 BMW M5  [9.50]
Cool
Those weights are in kg, sorry i am use to working with metric scale here in Canada. i will convert the weights to imperial in my original post.
      01-11-2011, 03:41 PM   #36
trsbmw
deft danish devil
Drives: BSM E86 M-Cp, LMB 335d M-Sport
2007 Z4 M Coupe  [0.00]
The Z4M came with bad looking wheels from the factory, period, end of story. This has been known since 2005 and is still the same today in 2010. Mostly the over 40 crowd like the more conservative look which is great but most under 40 like a little spunk to their car. This is a known pattern that has been going on for decades in the USA and Europe. The Z4M came with what the designers thought was a good looking wheel. Sad to say its not a good looking wheel, regardless of what a lot of people think.
Getting back to the original post I must say the 19 inch wheels appear to not be that heavy at all. I was very surprised. The Z4M 18s seem to be heavier.
Huh? Since when has how good something looks turned into an objective matter?
Remember that opinions are like buttholes, everyone has one, and they all stink.
      02-09-2011, 09:57 PM   #37
InterlagozzE86MCoupe
Drives: 2007 BMW M Coupe
those look hot on the M
      02-26-2011, 07:15 AM   #38
sho-one
MMA fighter and F1 test driver
Drives: Z4///M coupe bulletproof
Will the M3 Competition Rims fit 359 R on stock Z4MC?
thanks for any advice, i did a seach but can't find a difinitive answer
19"x9.0" +31mm Front
19"x10.0" +25mm Rear
NOW:08 M.Coupe SMB #102/248 #1669/1815
:|MORRVS8|APEX8|SS.X-pipe|SS.PW.Loop|AFE.intake|Matte.grill|short.ant|Z HP.knob|interior.LED|bulletproof
09 Audi Q5
THEN:96Accord|98Camry|04TSX SC|06 M3|06A4|05Civic Si|05Imprezza|05S2000|08FJ
      02-26-2011, 07:35 PM   #39
THE JEDI
Drives: 2005 Z4 2.5i
Hey I want to put some 255/40/17 on my stock rims for my z4 anyone see any problems. I'm rolling 235/45/17 in the rear..I'm going to move my 235 to the front and put the 255s on the back any problems..I'm hoping not, these came off my my old e34 5'r and these tires are so new they still have the factory markings on them...
      02-27-2011, 01:33 AM   #40
THE JEDI
Oh I Forgot On The Rear
      04-10-2011, 03:23 PM   #41
BruceJ
6 of Diamonds (ret)
BruceJ's Avatar
Drives: 2011 E93 335is
I stole the wheels off my moms E92 M3 and put them on my car to see the look. The offset is more aggressive in the front and rear then my OEM ZCPs. The front is more aggressive then my OEM ZCP with 15mm spacers. The 18s should fit just fine
awesome look
