      02-04-2023, 07:11 PM   #1
JackSlater
Drives: 2004 Z4 E85
No start no crank. HELP!
I'm nearing the end of my rope with my 2004 Z4 2.5 automatic. The car won't start or crank, no codes via INPA or my Foxwell scanner. I've replaced the battery, starter, ignition switch and neutral safety switch. Fuses are all good. Key is being read successfully according to INPA, though the starter motor is being blocked due to P/N. When I go into INPA to look at transmission information, there are question marks under selector lever position, which is why I thought it was the neutral safety switch and replaced it to no avail. On the dash the current gear does not display in the box between the tach and speedo, which I also attributed to the P/N switch, but after replacing, the box is still blank. Any input would be greatly appreciated, thanks for your time and consideration.
      02-04-2023, 11:47 PM   #2
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Can you confirm whether the TCU is getting power?
      02-06-2023, 06:18 PM   #3
Rafichicago
Rafichicago's Avatar
Drives: 2018 M5 2009 E63AMG Wagon
Have you checked ground strap ?
