      12-17-2013, 05:45 PM   #1
jsoltan
jsoltan's Avatar
Drives: 2007 BMW Z4 M Coupe, 13 328i
Nav reboots while driving and electrics semi shut down.
While driving in any gear and at any speed the nav screen shuts down and reboots and the car cuts out momentarily. At the same time key fob doesn't open door locks. Battery changed out to OEM in last 12
months. What could this be?
      12-18-2013, 12:33 AM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
Sounds like a loose connection from the battery to the fuse block.
Schematic attached, with the suspect connection noted.
WDS Wiring Diagram System.pdf
      12-18-2013, 04:08 AM   #3
jsoltan
jsoltan's Avatar
Thanks, Will check it out.
      04-30-2016, 01:33 PM   #4
Wolfbeef123
Drives: BMW Z4 M Roadster
On my car it was the voltage regulator, replaced the alternator and all fine now
