02-24-2011, 11:43 PM | #1 |
John 14:6
59
Rep 588
19x8 +30 and 19x9 +30 on a Non-M
Hey guys,
I've had a set of 19X8.5F +35 and 19X10R +35 (massive lip on the rear) fit before. Tires 235/35 front and 265/30 rear. Will a set of 19x8F +30 and 19x9R +30 fit a non-M roady? If so, should I go with 265 or 255 in the rear? TIA
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover... Last edited by misterawa; 02-26-2011 at 06:23 PM.. |
02-25-2011, 01:44 AM | #2 |
Rep 615
do it E!
i think the fronts will sit flush while the rears might have a little poke. im pretty sure your gonna need to stretch the tires as well.
'03 3.0i z4: tiag ext., red int., SMG, sport, premium
HAMANN exhaust l HAMANN front lip l 19" Miro type 366 (HAMANN edition race replicas) l RPI air scoop l KW v2 coilovers -*MY PICTURE THREAD*- |
02-25-2011, 09:31 AM | #3 | |
John 14:6
59
Rep 588
BTW, what's the offset on your wheels? I recall Bobby saying +32?
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover... Last edited by misterawa; 02-25-2011 at 10:03 AM.. |
02-26-2011, 07:02 AM | #4 |
Rep 509
Im a little interested in this too since I got some wheels that is 8.5x19 ET30 and 10x19 ET37.
OH FO SHO: Have you rolled your fenders? And what offset do you run? Thanks!
My Hellrot '06 BMW Z4 3.0si Coupe and My Mineral Grey '14 F30 (sold) New daily: Sunset Orange 330E G20 Instagram: @StigJ77 & @bmwe86driver |
02-26-2011, 11:37 PM | #5 |
John 14:6
59
Rep 588
Any issues of rubbing with the front wheels? What tire size u running (front & rear)?
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover... |
02-27-2011, 12:45 AM | #6 |
instagram 997turbotom
279
Rep 7,377
wow those look great
02-27-2011, 05:37 AM | #7 | |
Rep 509
I have some Michelin PSS ready. 235/35 and 265/30.
02-27-2011, 10:41 AM | #8 |
Rep 12,565
Tough call, my 8.5 rears are 42 offset with 12mm spacer effectively making it a 30mm offset and it sits pretty flush. Another half inch might be the max but I'm sure if you rolled the fenders it'd be ok. But I'd stick with a 255 to be safe.
02-27-2011, 02:19 PM | #9 | |
John 14:6
59
Rep 588
I really like the Wedssport wheels. Very light weight...19 lbs front and 20sh lbs rear.
02-27-2011, 06:23 PM | #10 | |
Rep 409
0.5" = 12.7mm using an 8.5" et50 as a starting point... installing a 9.0" et30 will move the outer edge of the wheel towards the fender line by 26mm (1 inch) and produce 14mm (9/16") more inner clearance to the shock. this is the exact same as putting an ///m rear on the car. installing a 10.0" et40 will move the outer edge of the wheel towards the fender line by 29mm (1-1/8") and REDUCE inner clearance by 9mm (5/16"). either install will require an increase of negative camber to sit flush with the fender line. the new setup will be less aggressive than the one you noted in the first post, but just barely. 235 tread in front may rub close to lock.
02-27-2011, 10:27 PM | #11 | |
John 14:6
59
Rep 588
02-28-2011, 08:48 AM | #12 | |
Rep 409
http://www.zpost.com/forums/showthread.php?t=344535 and this is the same car after lowering and camber adjust... http://www.zpost.com/forums/showthre...ht=urban+green next is a post from the brits... http://z4-forum.com/forum/viewtopic....849&hilit=et35 it's not exactly your wheel sizes, but they are very close. "dav the wheel nut" uses 8.5" et35 in front, which protrudes 1 mm farther than an 8.0" et30, and 9.5" et35 in rear, which protrudes 2 mm farther than a 9.0" et30. note he does not give any pics showing protrution on the wheel and tire set, probably because it sticks out quite a bit. also he says he used a 225 tread width in front. i concur with his reasoning and also recommend a 255 tread width for the rear. these sizes are less expensive, easier to come by, and perfect for full economy. heck, 225/35r19 and 255/30r19 are stock for the 335is which is a much heavier and longer car. really, unless you plan on tracking the car, there is no reason to go wider. obviously a wider tire looks better, but unless you're made of money, why put up with the headache of going through tires like you would toilet paper after creole? farther on down the post is "gookah's" car. he's also running the 8.5" and 9.5" et35 all around, and you can see how severe the camber is in the rear after lowering in order to get them to fit inside the fender line. i'm pretty sure the weds will look very good, but i'm also sure it's going to be very "aggressive".
02-28-2011, 12:49 PM | #13 |
Rep 509
Misterawa: Do you have a picture of you old/current setup that showes how the wheel sits? Did your rear wheels touch the fenders?
If your 10" ET35 with 265 fits without rubbing my will fit too I guess. Have you rolled the fenders?
02-28-2011, 12:59 PM | #14 |
Rep 409
here's a pic of 10.0" et40 (bbs ch) on stock suspension and max neg camber. it does stick out from the fender line. lowering coils or aftermarket camber plates could bring the top back in, but it would chew through tires super fast. notice the tires are already stretched for clearance.
02-28-2011, 01:14 PM | #15 |
Rep 509
Thanks for the pic. Then Ill be fine with the rear wheels if I shave off 3mm. Then Ill have ET40.
02-28-2011, 01:46 PM | #16 |
Rep 509
Another thing regarding the Wedssports, the front 8x19s should work fine. they will only extract 1mm more than my current setup (9x19 ET44) I only have a minor rub in the plastic wheelwell just behind the side reflectors when I really push it in the corners.
As for the rears they will retract 1mm if you compare it to a 9.5" ET35. I know bmwZ here on the board is running that spec in the rear. So all in all you should be fine with that setup Heres mine with 9x19 ET44 front AND rear. 235/35 and 255/30.
My Hellrot '06 BMW Z4 3.0si Coupe and My Mineral Grey '14 F30 (sold) New daily: Sunset Orange 330E G20 Instagram: @StigJ77 & @bmwe86driver Last edited by StigJ; 02-28-2011 at 02:15 PM.. |
02-28-2011, 02:31 PM | #17 | |
John 14:6
59
Rep 588
v3.0si, thx for all the calculations as well . I agree, it's gonna be an aggressive set up. What do you guys think about the following tire option 215/35/19 F (I'm considering this to hopefully reduce the rubbing) 235/35/19 R (from the front of my old set up & trying to save $ on buying new tires). I've seen people run 245/35 rear before. Let me know what you think...thx again you guys
02-28-2011, 02:42 PM | #18 |
Rep 509
Hmm... If your setup didnt rub at all I should be fine with ET37 then. Now Im wondering if I should try my wheels without shaving the senter....
But then again when I see the picture of v3.0si's Coupe Im a little confused.
02-28-2011, 03:59 PM | #19 |
Rep 409
the pic with the bbs ch's is courtesy of "veearrsix". i believe misterawa's car is lowered. veearrsix's is not.
02-28-2011, 04:03 PM | #20 |
John 14:6
59
Rep 588
Mine's lowered and at the time, had a lot of camber.
02-28-2011, 04:28 PM | #21 | |
Rep 409
02-28-2011, 05:19 PM | #22 | |
Rep 409
front = 225/35r19 rear = 255/30r19
