02-23-2018, 09:36 PM | #1 |
Rep 700
Solid Diff Mounts
Going to drop my diff soon for a 4.10 ratio swap.
Might as well give it a birthday party with some new diff mounts/bushings. Just ordered a set from Turner HERE Anyone tried running solid aluminium mounts on their diff? Should really tighten things up a bit compared to OEM and they are then maintenance free, never have to touch them again. Plenty of E46 guys have done it and they say the NVH is negligible.
02-24-2018, 12:44 AM | #2 | |
704
FD3S69.50 |
02-28-2018, 04:28 AM | #3 |
1621
Rep 4,294
I wouldn't say that then there is no maintenance mate, those vibes go somewhere, and that somewhere is where you fill find extra maintenance to do. But, do let us know how you find it. Interested in your feedback.
Powered by |
02-28-2018, 04:44 AM | #4 |
Rep 700
I will indeed report back after the install.
If you research the E46 subframe issues and broken diff support brackets you might be surprised to find that actually the opposite is true. It is suggested by those who know far more than I, that the factory flexible rubber mounts are responsible for causing the damage in the first place, solid mounts actually reduce mechanical stress. If you like axle tramp and wheel hop stick with the standard rubber bushings
MOEDARE140.00 |
02-28-2018, 07:24 AM | #5 | |
10866
Rep 4,895
Shore80A is usually the 'soft' polyurethane like the purple powerflex or red strongflex. Shore90A, shore95A or even stiffer is considered 'hard' (but nowhere near as hard as solid aluminium or Delrin). But shore80A is usually stiffer than the stock rubber, expecially when thats already a few years old (thats then more like shore70a although there are various stiffnesses in a car) I have shore80A as diffmounts and subframe mounts and have no whine etc what so ever. But I did choose shore80A over shore90A (which I put in most parts of the rest of my suspension) partly because of potential whine in those spots. Thats not possible from a technical pov imho. But that doesnt automatically means that solid mounts will cause problems.
02-28-2018, 05:23 PM | #6 | |
Get off my lawn
932
Rep 1,159
Drives: 6MT
Garage List 2023 GR Corolla [0.00]
2022 BMW X3 M40i [10.00] 2007 BMW Z4M Coupe [0.00] 2002 BMW 325xiT [0.00] 1991 BMW 318is [0.00] |
I have the Rogue Engineering engine and transmission mounts and the slight increase in NVH was noticeable but I am OCD. |
03-01-2018, 01:47 AM | #7 | ||
704
03-01-2018, 12:40 PM | #9 |
Rep 2,866
Noises Vibration Harshness
03-02-2018, 10:14 PM | #10 |
1621
Rep 4,294
Powered by |
03-03-2018, 09:49 AM | #11 |
Hug the road... Carpe Asphalt
105
Rep 722
Anyone installed these? How is the NVH compared to stock and how did it improve the driving experience?
Performance Polyurethane Differential Bushing: ES#: 2748535 ES#: 2748537 https://www.ecstuning.com/b-ecs-part...002447ecs01~a/ Product Details Your rear differential is indirectly connected to your right foot through the engine and driveline, and connected to the seat of your pants through the chassis. Soft factory rubber differential bushings absorb vibrations between chassis and differential, providing comfort and softness in both of these connections. Enter ECS Tuning's In-House Engineered Performance Polyurethane Differential Bushings. By eliminating the deflection factory rubber bushings permit, the connection between your right foot (and your seat) to the wheels is improved. Removal of this slop allows for crisper power transfer from differential to wheels, which means better throttle control while carving a canyon road, drag racing, sliding the rear end out, or just driving to work. This is achieved without the harshness or vibration associated with delrin or solid differential mounts. Featuring a tough 88A durometer polyurethane and Black anodized 6061-T6 aluminum Sleeve, our Performance Polyurethane Differential Bushings are more resistant to chemicals, ozone degradation, road salt, and general wear and tear than factory rubber bushings, resulting in a longer service life.
2007 BMW ///M Coupe
03-04-2018, 03:56 AM | #12 | |
704
03-04-2018, 08:01 AM | #13 | |
Rep 11,667
......as long as you still have some isolation on the sub-components. BMW is now running solid subframes on GTS etc. I'm installing solids on my M3 subframe with powerflex purple on the diff, so I guess I'll soon find out first hand :
03-04-2018, 08:16 AM | #14 |
10866
Rep 4,895
Yes but if you look at the base of the f82 subframe its about twice as wide as that from our cars. Its not a matter of NVH in the GTS, but a matter of forces.
The narrower the base of the subframe, the bigger the twisting forces. Twice the width, half the force
03-04-2018, 10:24 AM | #15 | |
Rep 11,667
In the case of the narrower subframe with more twisting forces, would it not be more beneficial to use solid bushings to minimize forces on the chassis and impart them more directly to the wheels? (subframe & chassis become unitized)
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 03-04-2018 at 10:32 AM.. |
03-04-2018, 11:30 AM | #16 | |
Rep 2,866
03-04-2018, 02:07 PM | #17 | |
10866
Rep 4,895
Any kind of dampening reduces peak forces and dissipates the total amount of energy over a longer timespan. So the softer the bushings, the lower the stress on the chassibolts and chassis itself (mainly the spotwelds). And the wider the chassisbolts/mounts, the more area it has to dissipate energy and the lower the lever forces. I dont know if its a real problem with the z4 but with the e46 its a major problem. Although that has also to do with a design flaw. With the z4 the rear subframe sits in a full cage (the rear tension/pull rods enclose both the petrol tank and the subframe) and with the e46 the subframe sits in a C section (the tension/pullrods dont enclose the rear subframe, just the petrol tank). But however you look at it, the subframe is much much stronger than the chassis so it can tear it up without any doubt. It obviously also has to do with what kind of mileage you expect from your car. If you do 2k miles/year and you expect to keep the car for another 5 years it wont be as much of a problem (20k miles), but usually a car is designed to last 200k miles or so without major disasters. you can also look at the front axle. The subframe from the fornt axle is bolted directly into the chassis, but again that subframe is twice the width if not more.
inTgr8r2431.50 |
03-04-2018, 02:27 PM | #18 |
Rep 11,667
Thanks, thats interesting!
I was aware of the E46 issues. The Z3 also had subframe problems
03-04-2018, 02:38 PM | #19 |
10866
Rep 4,895
I think if you want a stiffer rear setup its better to use stiffer bushings in the control arms.
First of all compression/expanding of those bushings has more effect on wheel geometry, and secondly if something in that department fails its much easier to repair. Just swap out cheap parts. Repair welding on chassis is much more expensive and its not always apparant where the damage sits. Look at the youtube video's redish motorsport puts up. They specialize in the e46 chassis and know it by heart to the spotweld where some of the problem areas are and that often means cutting out whole panels to get to certain enclosed box sections where internal damage sits. With the z4 chassis.... no one has that experience and if something goes wrong in that department you can be chasing that problem for years, cutting the whole car apart panel by panel. This video gives you an idea why you want to prevent damage to the body at any cost... The damage you see with your eye is only part of the story. Its the main reason why all my polyurethane bushings that directly touch the body arent stiffer than shore80a
inTgr8r2431.50 |
03-04-2018, 04:20 PM | #20 |
105
Rep 722
Thank you GuidoK for sharing all of this - very interesting. I'm sticking with the OEM rear diff bushings for now!
2007 BMW ///M Coupe
03-05-2018, 01:30 AM | #21 | ||
704
XMetal1137.50 |
03-06-2018, 10:19 AM | #22 | |
Rep 870
Drives: 2006 BMW Z4M Roadster
Salty
