      03-19-2011, 01:18 PM   #1
Mroadster
Drives: BMW Z4MR
Will these fit my Z4 M roadster?
here is the link:
http://toronto.kijiji.ca/c-cars-vehi...AdIdZ268235718
      03-19-2011, 01:53 PM   #2
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
Yes they will fit. These rims come on e92/e93 328i's that have sport package.
To get a flush fit you might need to run spacers especially on the rear.
And also keep in mind that the sidewall is one size smaller than what your car comes stock with.
If memory serves right you are looking at a 3.6% difference in overall diameter of the wheel.
This means that your speedometer will show a slightly higher speed than what you are actually doing AND you will be racking up more KMs on the car than you are actually travelling.
Although 3.6% is not a big difference its something to keep in mind.
And if these are the original tires that came with those rims they will be runflats too .. so rougher ride.
Just my 2c.
      03-19-2011, 06:53 PM   #3
3002 tii
3002 tii's Avatar
2286
Also keep in mind while these may be OEM wheels they are NOT CSL! As the member above pointed out these were the sport pkg wheels off the 328i. OEM CSL wheels from the E46 M3 were in 19" fitment. These will fit but they will not sit flush and frankly at $1400 it's a rip off.
Follow for latest mods
      03-21-2011, 04:27 PM   #4
Mroadster
Drives: BMW Z4MR
thanks for the help, I will not be picking them up.
      03-21-2011, 05:51 PM   #5
Mroadster
Drives: BMW Z4MR
I have decided to get 18'' Hyper black CSL rims. Regarding the offsets and clearances, what do I have to order? I want to order a set that will fit right on my Z4M Roasdter as is without having to put on spacers or anything else. I dont understand wheel fitment very well. Thanks in advance.
      03-23-2011, 03:14 PM   #6
l4zy
l4zy's Avatar
Drives: 95 M3, 15 i3, 17 M3 Frz Wht
2017 BMW M3  [0.00]
2015 BMW i3 REX  [0.00]
1995 BMW M3  [10.00]
2013 BMW X3 xDrive35i  [7.00]
in general, most wheels for the e46 m3 will fit our cars quite well so you shouldn't have too much trouble finding a set.
      03-25-2011, 11:20 PM   #7
vortex_tuning
Drives: E92 M3
These are not CSL wheels. These are for non-M E9X. The rear offset is high. The front should work. The rear will be tucked in quite a bit.
