05-10-2018, 08:51 PM | #1 |
Rep 71
Z4 M Oil temp?
Hello all,
I’ve been noticing my oil temp running slightly higher lately. To quantify... the gauge markings are: 120 . 210 . 300 In the 5 years & 40k mi I’ve been driving this car (‘07 Z4MC), the normal oil temp has been about halfway between the lower “.” And the 210 markings, maybe a little higher. In the last week, the needle has been coving the “2” in 210. Today in slow traffic at about 88 deg F ambient temp, the needle was right on 210, and occasionally got a needle width above that. The only time that I’ve seen the oil temp that high (until now) was coming off the track and the end of a session on a 85-90 deg day. What’s changed? I just had my indy shop flush & fill the coolant and do a valve adjustment (no actual adjustment required), so the valve cover was off. Maybe the radiator wasn’t “burped” correctly? I’d just like to check with the more experienced in the community here, and see what is considered a safe normal operating range. I’ve got a BMWCCA drivers school at the end of the month, and want to address anything before pushing the car too much in the heat. Thanks in advance for your ideas and any shared experience and observations. Gyro Last edited by GyroF-16; 05-10-2018 at 10:25 PM.. |
05-11-2018, 09:24 AM | #2 |
1820
Rep 5,337
Lack of airflow through the oil cooler will do that. I notice the oil temp creep up ever so often when I’m stuck in stop and go in L.A. traffic. Highest it’s ever been in traffic is about a needle’s width pst 210.
05-11-2018, 10:08 PM | #3 |
Rep 71
Thanks, Hack.
I was hoping to hear from you and/or Stickmon on experience with oils temps over the long term. I’m hoping it’s just the low airflow and high(er) ambient temps. I’ll be taking a longer drive tomorrow, so will see what it’s like then. |
05-11-2018, 10:38 PM | #4 |
636
Rep 3,124
Yep, what Hack said.
I sit in LA traffic all the time, and get about 2 needles past 210. Water temp gets to about 199 and then the fan kicks in and takes it down to about 195. Just hit 175k miles yesterday on the way home from work. I'm officially declaring it mathematically impossible for anything on my car to fail prematurely.
v3.2mc94.00 |
05-12-2018, 09:07 PM | #7 | |
Rep 3,004
175K Miles!!!!
Racerbruce
05-12-2018, 11:11 PM | #8 | |
Rep 2,542
I believe you can view the coolant temp using the hidden menu in the instrument cluster. In slow traffic, the oil temp can creep a little since there's less airflow for the oil cooler. |
05-13-2018, 02:58 AM | #9 | |
636
Rep 3,124
Vanos exhaust hub (C300) Rod bearings at about 127k miles Timing chain guide Voltage regulator Throttle position sensor Belt idlers 'bout it. She leaks oil like a sieve. I'm waiting for the water pump to explode. Then I'll take her to Lang for a whole new water and oil cooling system and fix the oil leaks.
05-13-2018, 09:22 PM | #10 | ||
Rep 2,051
05-13-2018, 10:05 PM | #11 |
636
Rep 3,124
If it's a 2006, you want to do Vanos to camshaft bolts.
At some point in 2007 they came with the upgraded bolts. Inspect the exhaust hub when you do valve adjustments and replace it when it fails. Usually only one tab fails. Most peeps find it when they do the valve adjustment. The timing chain guide will be pretty well frazzed by 100k miles. Replace it with the better Beisan guide when you have the Vanos off for other reasons. Get your used oil tested and do rod bearings when your lead goes vertical. Everything else is pretty much run-to-fail.
05-16-2018, 09:31 AM | #12 |
Rep 93
Oil temp usually runs a bit above coolant temp. Anything up to 250 F. is fine but if it goes higher start worrying with dino oil. Full synthetic can go all the way to 300 deg. The Ms run full synthetic, so nothing mentioned here posed any issues.
You actually want it to go a bit above 220 or so sometimes to burn off some combustion byprducts. Last edited by wspohn; 05-17-2018 at 11:20 AM.. |
05-17-2018, 10:42 AM | #13 | |
Rep 71
May I ask where those numbers come from? I’m a professional pilot (have been all my adult life), and am accustomed to a manual with “operating limitations” in it... so I appreciate the experience of those on this forum, so I can continue to learn what is “normal.” Thanks again! |
05-17-2018, 10:45 AM | #14 | |
Rep 71
That’s about the best summary of S54 maintenance/ failure items that I’ve seen yet. |
05-17-2018, 11:19 AM | #15 | |
Rep 93
