      05-08-2018, 05:57 PM   #1
DeutschRennfahrer
DeutschRennfahrer's Avatar
39
Drives: 2006 Z4 3.0i - Saphire Black
Stripped Oil drain pan bolt
The oil drain pan in my Z4 seems to be stripped; I can't completely tighten the bolt and it is leaking a little bit of oil.
The shop is telling me that I need to completely replace the drain pan, which apparently requires removing the front subframe and is estimated to cost $1500.
According to the mechanic, the drain pan is too thin to do a tap and die rethreading, and that this often fails.
Has anyone ever experienced this? Is full replacement really my only option? Any advice is appreciated.
      05-08-2018, 06:04 PM   #2
Reborn_
Drives: 2007 BMW Z4MC
I'm not an expert on the wall thickness or design of the Z4 oil pan, but if they have it threaded to begin with, I don't see how you couldn't bore it out slightly and tap it. I would make sure to use one of those quick release style drain bolts so that you don't have to thread it in and out any more. That price sounds a bit high - I would quote the job elsewhere to be sure.
      05-08-2018, 06:49 PM   #3
StickMon
StickMon's Avatar
Drives: 2006 MR
Now see here:
http://www.zpost.com/forums/showthread.php?t=453834
Near the bottom of page 2 is the good news from SCHMOUPE:
"For anyone interested in my saga, I finally got everything together and attempted the thread fix this morning. Excited to say it all went perfectly smooth. I managed to snap a few pics along the way. Maybe sometime next week I will sit down and do a proper DIY thread. I am also going to sell my time sert kit."
Then you might want to install a Fumoto F-109 Engine Oil Drain Valve. That's what I did.
Or use top-side oil extraction.
      06-02-2018, 07:45 PM   #4
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
Fix
http://www.zpost.com/forums/showthre...4#post23276694
Here
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
