      05-29-2014, 08:22 AM   #1
SwissArmy
Why so serious?
SwissArmy's Avatar
REQUEST: E85 SMG ECU Diagram
As the title states,
I am looking for the E85 SMG ECU Diagram. Please and thank you
EDIT: I am experiencing the P0700 code
      05-29-2014, 11:18 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
Have you tried the WDS?
I think you were looking for the trans oil temp sensor?
I can't find it. Just the pressure sensor.
Maybe that's why you can't find the wire.
      05-30-2014, 09:29 AM   #3
SwissArmy
Why so serious?
SwissArmy's Avatar
Thanks StickMon!
I was on the E46 M3 board, and someone said that we don't have a trans oil temp sensor. The z4 SMG is not the SMG2 but a different H-SMG similar to the SSG.
I am getting the P0700 code. I am going to get my local indy to scan the codes and see what Transmission issue I am experiencing. Probably need a new battery, and a new fluid change. Though, I did one last year...hmm
      06-13-2014, 03:44 PM   #4
DerekSelmanRacing
DerekSelmanRacing's Avatar
Drives: 05 Z4 3.0 SMG, 01 530
Curious as to your present situation.
I BELIEVE the P0700 code on the SMG may indicate failure of the shift mechanism but doesn't specify which component. My car indicated a complete failure a couple years ago which, after further analysis, was cured with a pump replacement. My problem began as intermittent no-shift when under hard use and progressed to failure under normal use.
Obviously, low voltage caused by alternator/battery/load issues would play havoc with shifting.
