      05-11-2014, 03:35 PM   #1
z4brownderby
Drives: 05 z4 3.0
Question z4 2005 horn
both horns on my z4 stopped working at the same time. Mechanic says to replace same.
      05-11-2014, 11:36 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
That's statistically highly improbable.
I'd be suspicious.
Did you check the fuse? Can you test the horns yourself?
      05-12-2014, 08:55 AM   #3
z4brownderby
Drives: 05 z4 3.0
both fuses tested o k . no horn sound, but you can hear the relay click when you press on the horn button
      05-12-2014, 08:59 AM   #4
z4brownderby
Drives: 05 z4 3.0
Where are they located?
      05-12-2014, 11:06 PM   #5
StickMon
StickMon's Avatar
Drives: 2006 MR
Darn good question.
The only time I remember seeing mine was when I had the front bumper cover off.
I just went out and probed around with a flashlight and I can't find them.
Ahhh! A search shows that Finnegan has already solved this one.
      05-19-2014, 01:40 PM   #6
z4brownderby
Drives: 05 z4 3.0
Originally Posted by StickMon View Post
Darn good question.
Thanks to Finnegan.
      05-20-2014, 03:24 PM   #7
dharper
BMW CCA Member
dharper's Avatar
Drives: '19 BMW X3 30i-'11 BMW 128i
I had the high tone go out on my '03, so it's not out of the realm of possibility. It's not too hard to remove the front bumper to get to them, and it'll be worth the time to do so instead of reaching up/around plastic panels to get to them on either side.
      05-22-2014, 11:59 PM   #8
JeffchaPz
JeffchaPz's Avatar
17
Drives: 2007 Z4M
I replaced both with after market ones and they would work once or twice and they would stop working after that.... I checked the fuses and they were both OK. I went on line and I read to replace the 5 fuse for a 25 amp/volts not sure how that's measured... but yeah.... use a higher capacity fuse and give it a try. Make sure the sure the car Key is not in the eng when changing the fuse.
Good luck
