03-09-2018, 07:59 AM | #23 | |
Rep 373
StickMon635.00 |
03-10-2018, 07:48 AM | #24 | |
Rep 870
Drives: 2006 BMW Z4M Roadster
Salty
03-11-2018, 04:04 AM | #26 | |
635
Rep 3,124
Sounds like its worth another go. Next up: Formula-H ! Heck, Formula-H endurance racing with 10,000 psi refueling stops !
03-11-2018, 09:26 AM | #27 | ||
Rep 2,045
03-11-2018, 09:32 PM | #28 | |
Rep 870
Like most everyone else, I'm just accepting as a maintenance expense. I don't like it, but I'm accepting it. Salty
03-12-2018, 07:50 PM | #29 |
Rep 1
This is very intriguing information for me as an E46 M3 owner. I always look for the presence of copper in my oil samples from the S54, but after reading this it looks like I need to be looking for the absence of lead!
In the E46 M3 world, it seems like 100k miles is the agreed upon time to consider bearing changes. I wouldn't have thought the S54s in the Z4 Ms would likely need replacement around 60k.. |
03-15-2018, 07:36 PM | #30 | |
Rep 3,004
148,000 miles! I wonder if the rod bearings were replaced....
Racerbruce
03-15-2018, 07:42 PM | #31 |
Rep 3,004
128,000 miles....
Racerbruce
03-15-2018, 10:07 PM | #32 |
Rep 3,285
Drives: 2002 M5;2007 M Coupe;2020 M2C
If you go on any car forum that centers on cars with S54, S62, S65, or S85 engines you will find countless threads on bearing failures. The S62 is probably the least affected to the relatively low 7K RPM limiter. For the others (outside the early S54s, where there was clearly a problem) the issue almost to be expected given the high RPMs and power output. Certainly wear can be minimized by driving conservatively until the oil temperature is appropriate. As mentioned, in the end UOA and/or preventive replacement are necessary.
My E39 M5 has 92K miles now, with a clean UOA; I'll probably do the bearings at 120K miles or so (if it ever gets there as I don't drive it much). For the M coupe, which has 30K, I'm planning on changing them at 60K miles. My lead levels on the coupe have actually been coming down, for whatever reason.
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
03-16-2018, 05:30 PM | #33 |
Rep 870
Just curious what you guys think about >100K miles on the S54? At one time, I was thinking 150K was about as much as one could hope to get out of a Z4M, but since we now know rod bearings are 50-60K maintenance, and VANOS rebuild is maintenance, and timing chain guide is maintenance, and if all other standard BMW maintenance is done like cooling system swaps, fluid swaps, bushings, etc, is 200K, 250K no problem for a well-maintained S54?
03-16-2018, 06:20 PM | #34 | |
Where Does He Get Those Wonderful Toys?
94
Rep 290
03-16-2018, 06:41 PM | #35 | |
Rep 528
Drives: E86 Z4MC; E92 M3
I seem to recall one particular E46 M3 on M3Forum that was over 300k miles with the maintenance documented. Unfortunately it was written off in an accident so nobody ever got to see just how far it could go. As Boosted mentioned, the wealth of knowledge now available to us only helps us. It also opens the door for various suppliers to create and improve on components (various VANOS fixes, coated/treated bearings that are constantly improved and introduced).
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE E90 M3 Sedan 6MT Jerez Black/Fox Red GONE E86 Z4M Coupe Interlagos Blue/Black E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread |
03-16-2018, 08:57 PM | #36 |
Rep 335
I honestly think this issue is over hyped. I saw one guy who changed them out on YouTube after about 100,000 miles. They were worn but certainly not about to "go" anytime soon. There were some 80,000 e46 M3s produced. From what you read online it would seem that they are all ready to blow. There have got to be tens of thousands of M3s that have 150,000 miles and no issues. I would guess that 95% are totally fine for 150k. Maybe 99%. I wish I had data to back that up. I'm sure it's out there somewhere
03-17-2018, 02:27 AM | #37 |
635
Rep 3,124
Changed my bearings at 127k miles.
Currently at 173k miles. Car looks like hell, leaks oil like a mutha. Sounds great, runs great. Plan to get at least 250k out of it. Maybe 300k.
wdb4673.00 |
03-17-2018, 07:47 AM | #38 |
Rep 373
Mine's on 156k.
Doesn't use a drop of oil between (7,000 mile) oil services. Runs like a dream. Could use a bit of TLC to the paintwork. No rust, but lots of stone chips & swirls from being a motorway/highway daily driver. One small dent in the bonnet/hood from a roof tile. Can't be bothered to respray/detail it as the last (expensive) external detail I had lasted about a month before it looked about the same, due to the winter road conditions (rain, snow, salt, gravel, mud, grease, etc.). Mine can go from this... ...to this... ...to this... ...and back to this... ...in a matter of hours. Last edited by mmm-five; 03-17-2018 at 07:54 AM.. |
wdb4673.00 |
03-17-2018, 09:57 AM | #39 |
Rep 335
03-18-2018, 02:07 AM | #40 |
635
Rep 3,124
A little frazzed, but with some life left, probably.
http://www.zpost.com/forums/showpost...7&postcount=26
03-19-2018, 09:39 AM | #41 |
Rep 3,004
Did BMW change the oil spec in the early 2000's during the rod bearing recall to this? If yes, does anyone have info re the difference between the original spec and the new spec oil?
Castrol 07-51-0-009-420 TWS Synthetic Oil 10W60: 832511
Racerbruce
03-19-2018, 10:22 AM | #42 |
Rep 528
Yes, I don't have specific details but this was before they introduced the 10W60. Referencing the owner's manual of a 2001 E46 M3, it looks like they suggested 5W40 or 5W30 as the approved oils.
03-19-2018, 11:34 AM | #43 |
Rep 3,004
I believe this important info from Lang Racing has been presented before, but it's interesting to note that Lang states the previous rod bearings were too small and the rod bolts AND entire rod changed design....
https://www.langracing.com/finding-a...aring-failure/
Racerbruce
